StarTech.com 2x USB Car Charger 24W / 4.8A
Quicklinx: C9WVWS00 Mfr#: USB2PCARBKS
More than 50 in stock
£10.89 ex VAT
£13.06 inc VAT
Charge two tablets simultaneously, in your car. This 2-port car charger lets you charge two mobile devices simultaneously, while you're driving.
The charger can deliver 24 watts of power in total, sharing 4.8 amps of power between both ports. This means that you can charge two tablets at the same time.
The dual-port charger features Smart IC technology, which enables it to identify what type of device is connected to each port. By recognizing the attached device, the charger delivers the optimal charge that's specific to each device.
The charger supports USB Battery Charging Specification 1.2, which ensures compatibility with a broad range of mobile devices, including the Apple iPhone and iPad, the Microsoft Surface tablet, the Samsung Galaxy Tab, Nexus phones and more. When you're traveling with a passenger, you can charge their device as well as yours, and ensure that both of your mobile devices are ready when you arrive.
StarTech.com Dual Port USB Car Charger - High Power 24W/4.8A - Black - 2-Port USB Car Charger - Charge two tablets at once (USB2PCARBKS) car power adapter
Car power adapter
30 g
Output Connector Type
USB
12 - 24 V
Voltage Provided
5 V
P/N: USBLT1MW, USBLT1MWS, USBLT2MBR, USBLT2MW, USBLT30CMW, USBLTM1MBK, USBLTM1MWH, UUSBHAUB1RA, UUSBHAUB3, UUSBHAUB3LA, UUSBHAUB3RA, UUSBHAUB6IN, UUSBHAUB6RA
Car power adapter
30 g
Enclosure Colour
12 - 24 V
Input Connectors
Automobile cigarette lighter
Input Connectors Qty
1
Voltage Provided
5 V
Output connectors
Total 2: 4 pin USB Type A
Power Provided
24 Watt
Max Electric Current
4.8 A
FCC, RoHS, WEEE
C9WV StarTech.com Dual Port Car Charger with Apple 8-pin Lightning Connector and USB 2.0 Port In Stock £25.95
C9WV StarTech.com Car Charger - Micro USB & USB In Stock £10.25
C9WV StarTech.com Car Charger - Lightning & USB In Stock £25.85
C9WV StarTech.com 2x USB Car Charger 24W / 4.8A In Stock £10.89
Price Range Ex VAT: 0 - 50
