Brand
StarTech.com 2U Rack Mount Cantilever 2 Post Shelf - Mid/Center Server Rack- 150lbs / 68kg
Quicklinx: 887PWS00 Mfr#: CABSHF2POST
Product Type: Rack shelf, Rack shelf
Hurry, only 2 left in stock!
£55.54 ex VAT
£66.64 inc VAT
Add a high capacity mid-mount fixed shelf to almost any standard 2 post server rack. The CABSHF2POST 2U Heavy Duty Mid-Mount Rack Mount Shelf for 2 Post Racks allows you to add a high capacity mid-mount fixed shelf to almost any standard 2 post server rack.
The included mounting brackets can be adjusted to accommodate different post depths, making this 2U shelf a universal solution for 2 post rack storage. Constructed using 1.6mm SPCC commercial grade cold-rolled steel, this durable 2 post rack shelf can hold up to 67kg (150lbs) of equipment - a perfect solution for storing non-rackmount equipment, tools, peripherals or accessories in your rack to keep them readily accessible.
StarTech.com 2U Rack Mount Cantilever Shelf - Mid / Center Mount Server Rack Cabinet Shelf - 150lbs / 68kg - 2 Post Shelf (CABSHF2POST) - rack shelf - 2U
Rack shelf
Rack Size
19"
Height (Rack Units)
2U
Product Material
Cold-rolled steel
48.4 cm x 55.2 cm x 8.8 cm
4.4 kg
Adjustable depth, cantilever
P/N: 2POSTRACK42, RK12OD
Rack shelf
Product Material
Cold-rolled steel
Rack Size
19"
Height (Rack Units)
2U
48.4 cm
55.2 cm
8.8 cm
4.4 kg
Weight Limit
67.9 kg
Mounting Kit
Included
RoHS
Limited warranty - lifetime
887P StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg In Stock £25.48
887P StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg In Stock £34.10
887P StarTech.com 2U Rack Mount Cantilever 2 Post Shelf - Mid/Center Server Rack- 150lbs / 68kg In Stock £55.54
Stock Status: In stock
