Add a high capacity mid-mount fixed shelf to almost any standard 2 post server rack. The CABSHF2POST 2U Heavy Duty Mid-Mount Rack Mount Shelf for 2 Post Racks allows you to add a high capacity mid-mount fixed shelf to almost any standard 2 post server rack.
The included mounting brackets can be adjusted to accommodate different post depths, making this 2U shelf a universal solution for 2 post rack storage. Constructed using 1.6mm SPCC commercial grade cold-rolled steel, this durable 2 post rack shelf can hold up to 67kg (150lbs) of equipment - a perfect solution for storing non-rackmount equipment, tools, peripherals or accessories in your rack to keep them readily accessible.
- StarTech.com 2U Rack Mount Cantilever Shelf - Mid / Center Mount Server Rack Cabinet Shelf - 150lbs / 68kg - 2 Post Shelf (CABSHF2POST) - rack shelf - 2U
- Product Type
- Rack shelf
- Black
- Rack Size
- 19"
- Height (Rack Units)
- 2U
- Product Material
- Cold-rolled steel
- 48.4 cm x 55.2 cm x 8.8 cm
- 4.4 kg
- Adjustable depth, cantilever
- Limited lifetime warranty
- Designed For
- P/N: 2POSTRACK42, RK12OD
- Product Type
- Rack shelf
- Product Material
- Cold-rolled steel
- Rack Size
- 19"
- 2U
- 48.4 cm
- 55.2 cm
- 8.8 cm
- 4.4 kg
- Black
- Weight Limit
- 67.9 kg
- Mounting Kit
- Included
- RoHS
- Limited warranty - lifetime
- Designed For
