StarTech.com 2U Double-Sided Horizontal Cable Management Panel with Finger Duct & D-Ring Hooks
Quicklinx: 9PRJWS00 Mfr#: CMPNL2U
Select:
£43.36 ex VAT
£52.03 inc VAT
Organize horizontal cabling in your server rack, with a combination Finger Duct / D-Ring Hook panel. The CMPNL2U 2U Horizontal Cable Management Panel mounts to a standard 19" 2 or 4-post server rack to help you organize horizontal cabling, using the combination of a finger duct and D-Ring Hooks.
Constructed of high-quality steel, the cable organizer is designed as a double-sided solution offering cable management on both the front and back of the panel. The front is equipped with 4 horizontal D-Ring hooks, while the back has 2 additional hooks as well as a cable duct with a series of fingers that help you route your cables where you need them, and reduce cable strain in the process..
As an added benefit, the panel also promotes proper airflow through the rack by closing off open spaces between equipment. For easy installation, this horizontal cable organizer comes complete with 2 sets of rack screws (10/32 and 12/24).
StarTech.com 2U Double-Sided Horizontal Cable Management Panel with Finger Duct & D-Ring Hooks - Rack Cable Organizer / Manager (CMPNL2U) rack cable management panel - 2U
Rack cable management panel
Package Content
4 screws (10-32), 4 screws (12-24), 24 cable clamps, 8 nuts
Height (Rack Units)
2U
Product Material
Steel
48.2 cm x 10.22 cm x 8.81 cm
1.4 kg
P/N: 2POSTRACK12, 2POSTRACK16, 2POSTRACK42, RK1224WALHM, RK1232WALHM, RK1233BKM, RK12WALHM, RK12WALLO, RK12WALLOA, RK1520WALHM, RK15WALLO, RK15WALLOA, RK1820WALHM, RK1833BKM, RK2433BKM, RK2537BKM, RK2620WALHM, RK4236BKB, RK4242BK24, RK4242BK30, RK616WALM, RK920WALM, RK960CP, RK9WALM, RKQMCAB12V2
Product Material
Steel
Package Content
Height (Rack Units)
2U
48.2 cm
10.22 cm
8.81 cm
1.4 kg
RoHS
P/N: 2636CABINET, 2POSTRACK12, 2POSTRACK16, 2POSTRACK42, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RK1219SIDEM, RK1219WALLOH, RK1224WALHM, RK1232WALHM, RK1233BKM, RK1236BKF, RK12WALHM, RK12WALLO, RK12WALLOA, RK1520WALHM, RK15WALLO, RK15WALLOA, RK1820WALHM, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK2620WALHM, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RK616WALM, RK619WALLOH, RK812WALLO, RK812WALLOA, RK819SIDEM, RK819WALLOH, RK920WALM, RK960CP, RK9WALM, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12
9PRJ StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 2.2x3.9in (5.7x10cm) In Stock £3.06
9PRJ StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 2.2x5.9in (5.7x15cm) In Stock £4.79
9PRJ StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) In Stock £3.40
9PRJ StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) In Stock £7.01
9PRJ StarTech.com 1U Velcro Horizontal Server Rack Cable Management Panel - 4 Loop Cable Organizer In Stock £12.40
9PRJ StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel In Stock £36.86
Product Type: Rack cable management panel
Price Range Ex VAT: 0 - 50
