StarTech.com 2U 22in Depth Fixed Rack Mount Shelf - 50lbs / 22kg
Quicklinx: 887DWS00 Mfr#: CABSHELF22
Product Type: Rack shelf, Rack shelf
Hurry, only 2 left in stock!
£36.00 ex VAT
£43.20 inc VAT
Add a sturdy, 22in depth fixed shelf into almost any server rack or cabinet. The CABSHELF22 2U 22in Depth Fixed Rack Mount Shelf lets you add a compact, 2U shelf to virtually any standard 19-inch server rack or cabinet with front mount options.
The high-quality rack shelves are designed to withstand harsh work environments with ease. Constructed using SPCC commercial grade cold-rolled steel, this durable fixed rack shelf can hold up to 22kg (50lbs) of equipment - a perfect solution for storing small, non-rackmount equipment, tools, peripherals or accessories in your rack to keep them readily accessible.
StarTech.com 2U Fixed Server Rack Mount Shelf - 22" Deep Steel Universal Cantilever Tray for 19" AV, Data, Network Equipment Rack - 50lbs (CABSHELF22) rack shelf - 2U
Rack shelf
Rack Size
22"
Height (Rack Units)
2U
Product Material
Cold-rolled steel
48.27 cm x 55.88 cm x 8.8 cm
4.1 kg
P/N: 2POSTRACK12, 2POSTRACK16, 2POSTRACK42, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKHD, RK1233BKM, RK1236BKF, RK12OD, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RK8OD, RK960CP
Rack shelf
Product Material
Cold-rolled steel
Rack Size
22"
Height (Rack Units)
2U
48.27 cm
55.88 cm
8.8 cm
4.1 kg
Weight Limit
22.6 kg
Mounting Kit
Included
RoHS
Limited warranty - lifetime
P/N: 2636CABINET, 2POSTRACK12, 2POSTRACK16, 2POSTRACK42, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RK1233BKM, RK1236BKF, RK12OD, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RK8OD, RK960CP
Stock Status: In stock
