Vertically mount your server or networking equipment to a wall, in this low-profile cabinet. The RK219WALVO 2U 19-inch Steel Side Mount Rack is a Wall Mountable Server Rack that provides a robust solution for mounting your telecom, network or server equipment.
This 2U rack can be mounted to a wall or directly under a desk/table, expanding your workspace and keeping equipment easily accessible.
Perfect for SOHO (Small Office, Home Office) environments, the wallmount rack offers a space-saving installation for environments lacking the footprint space for a full-size server equipment rack. The rack allows your equipment to be mounted vertically - non-rackmount equipment can be installed using the rack as a wall case/chassis.
Constructed to EIA-RS310 19-inch rack standards, the RK219WALVO features a sturdy steel design.
- StarTech.com 2U Vertical Wall Mount Mount Server Rack - Low-profile 2 Post Server Cabinet for Switch, Router or Network Equipment - 61.2 lbs capacity (RK219WALVO) - rack - 2U
- Product Type
- Rack
- Placing / Mounting
- Wall mountable
- Black
- Rack Size
- 19"
- Height (Rack Units)
- 2U
- Product Material
- Steel
- 11.8 cm x 50.5 cm x 55.3 cm
- 8 kg
- Limited lifetime warranty
- Product Type
- Rack
- Wall mountable
- Product Material
- Steel
- Rack Size
- 19"
- 2U
- 11.8 cm
- 50.5 cm
- 55.3 cm
- 8 kg
- Black
- Weight Limit
- 27.7 kg
- Mounting Kit
- Included
- RoHS
- Limited warranty: - lifetime
