StarTech.com 2U 19" Cable Management Panel
Quicklinx: BGC3WS00 Mfr#: CMPNL2UCD
Organize horizontal and vertical cabling in your server rack, with a full-featured combination panel of finger ducts and D-ring hooks. No more tangled mess in your server room or data center. This one-piece organizer with 2U design provides an effective solution to cable management, helping you to keep all of your cables accessible and identifiable, for a tidier, more scalable server workspace.
The 2U cable manager makes it easier to manage cables from the front or back of your server rack, with conveniently placed hooks that hold both vertically and horizontally running cables.
The organizer helps you manage network, server and KVM cabling in your server rack by utilizing a combination of horizontal finger ducts and vertical or horizontal D-ring hooks. It organizes and guides cable using 24 lockable clips to keep cables securely in place.
Engineered with high-quality steel construction and sturdy hooks, the cable organizer is built to deliver dependable performance, year after year.
Adding the cable organizer in between your equipment also closes off open spaces in the rack, which promotes proper airflow. By relieving cable strain, it also increases the lifespan of your server and networking equipment interfaces.
Note: The hooks on this cable management system extend past 19 inches. As a result certain racks with close spaced or inset rack mount holes may not be compatible with this product.
  • Easy cable organization for a more manageable server room
    The 2U cable manager makes it easier to manage cables from the front or back of your server rack, with conveniently placed hooks that hold both vertically and horizontally running cables. The organizer helps you manage network, server and KVM cabling in your server rack by utilizing a combination of horizontal finger ducts and vertical or horizontal D-ring hooks. It organizes and guides cable using 24 lockable clips to keep cables securely in place.
  • Durable construction ensures dependable performance
    Engineered with high-quality steel construction and sturdy hooks, the cable organizer is built to deliver dependable performance, year after year. Adding the cable organizer in between your equipment also closes off open spaces in the rack, which promotes proper airflow. By relieving cable strain, it also increases the lifespan of your server and networking equipment interfaces.
StarTech.com Server Rack Cable Management -2U - Finger Ducts / D-Ring Hooks - rack cable management panel - 2U
Rack cable management panel
Rack Size
19"
Height (Rack Units)
2U
Product Material
Steel
51.6 cm x 8.8 cm x 15.2 cm
1.6 kg
P/N: RKCONS1708K, RKCONS1716K
Product Material
Steel
Rack Size
19"
Height (Rack Units)
2U
51.6 cm
8.8 cm
15.2 cm
1.6 kg
Mounting Kit
Included
RoHS
Limited warranty: - 2 years
