StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg
Quicklinx: 887NWS00 Mfr#: CABSHELFV
Product Type: Rack shelf, Rack shelf
18 in stock
£26.04 ex VAT
£31.24 inc VAT
Add a sturdy, vented shelf into almost any server rack or cabinet. The CABSHELFV 2U 16in Depth Universal Vented Rack Mount Shelf lets you add a compact, 2U shelf to virtually any standard 19-inch server rack or cabinet with front mount options. This TAA compliant product adheres to the requirements of the US Federal Trade Agreements Act (TAA), allowing government GSA Schedule purchases.
Our vented rack shelves improve air flow and help to lower temperatures in the rack. Constructed using SPCC commercial grade cold-rolled steel, this durable fixed rack shelf can hold up to 22kg (50lbs) of equipment - a perfect solution for storing small, non-rackmount equipment, tools, peripherals or accessories in your rack to keep them readily accessible.
StarTech.com 2U Server Rack Shelf - Universal Vented Cantilever Tray for 19" Network Equipment Rack & Cabinet - Heavy Duty Steel - 50lb - 16" Deep (CABSHELFV) rack shelf - 2U
Rack shelf
Rack Size
19"
Height (Rack Units)
2U
Product Material
Cold-rolled steel
48.27 cm x 40.64 cm x 8.8 cm
2.6 kg
Vented, cantilever
P/N: 2POSTRACK12, 2POSTRACK16, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKHD, RK1233BKM, RK1236BKF, RK12OD, RK1833BKM, RK2433BKM, RK2536BKF, RK2537BKM, RK4236BKB, RK4242BK24, RK4242BK30, RK8OD, RK960CP, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12
Rack shelf
Product Material
Cold-rolled steel
Rack Size
19"
Height (Rack Units)
2U
48.27 cm
40.64 cm
8.8 cm
2.6 kg
Weight Limit
22.6 kg
Mounting Kit
Included
Vented, cantilever
RoHS
Limited warranty - lifetime
P/N: 2636CABINET, 2POSTRACK12, 2POSTRACK16, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RK1233BKM, RK1236BKF, RK12OD, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RK8OD, RK960CP, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12
887N StarTech.com 50 Pkg M5 Mounting Screws for Server Rack Cabinet In Stock £15.93
887N StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £12.71
887N StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £33.51
887N StarTech.com Black Standard Universal Server Rack Cabinet Shelf In Stock £27.15
887N StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet In Stock £14.36
887N StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £29.51
887N StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £55.08
887N StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £58.24
887N StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg In Stock £22.35
887N StarTech.com 1U Adjustable Mounting Depth Rack Mount Shelf - Heavy Duty Shelf - 175lbs / 80kg In Stock £63.41
887N StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - Heavy Duty - 250lbs / 113kg In Stock £80.98
887N StarTech.com 2U 22in Depth Fixed Rack Mount Shelf - 50lbs / 22kg In Stock £36.00
887N StarTech.com 2U 22in Vented Rack Mount Shelf – Fixed Server Rack Cabinet Shelf - 50lbs / 22kg In Stock £39.56
887N StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg In Stock £26.04
887N StarTech.com 2U Rack Mount Cantilever Shelf - Heavy Duty Fixed Server Rack Shelf - 125lbs / 56kg In Stock £44.60
Price Range Ex VAT: 0 - 50
