Add a sturdy, vented shelf into almost any server rack or cabinet. The CABSHELFV 2U 16in Depth Universal Vented Rack Mount Shelf lets you add a compact, 2U shelf to virtually any standard 19-inch server rack or cabinet with front mount options. This TAA compliant product adheres to the requirements of the US Federal Trade Agreements Act (TAA), allowing government GSA Schedule purchases.
Our vented rack shelves improve air flow and help to lower temperatures in the rack. Constructed using SPCC commercial grade cold-rolled steel, this durable fixed rack shelf can hold up to 22kg (50lbs) of equipment - a perfect solution for storing small, non-rackmount equipment, tools, peripherals or accessories in your rack to keep them readily accessible.
- StarTech.com 2U Server Rack Shelf - Universal Vented Cantilever Tray for 19" Network Equipment Rack & Cabinet - Heavy Duty Steel - 50lb - 16" Deep (CABSHELFV) rack shelf - 2U
- Product Type
- Rack shelf
- Black
- Rack Size
- 19"
- Height (Rack Units)
- 2U
- Product Material
- Cold-rolled steel
- 48.27 cm x 40.64 cm x 8.8 cm
- 2.6 kg
- Vented, cantilever
- Limited lifetime warranty
- Designed For
- P/N: 2POSTRACK12, 2POSTRACK16, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKHD, RK1233BKM, RK1236BKF, RK12OD, RK1833BKM, RK2433BKM, RK2536BKF, RK2537BKM, RK4236BKB, RK4242BK24, RK4242BK30, RK8OD, RK960CP, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12
- Product Type
- Rack shelf
- Product Material
- Cold-rolled steel
- Rack Size
- 19"
- 2U
- 48.27 cm
- 40.64 cm
- 8.8 cm
- 2.6 kg
- Black
- Weight Limit
- 22.6 kg
- Mounting Kit
- Included
- RoHS
- Limited warranty - lifetime
- Designed For
- P/N: 2636CABINET, 2POSTRACK12, 2POSTRACK16, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RK1233BKM, RK1236BKF, RK12OD, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RK8OD, RK960CP, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12
StarTech.com 50 Pkg M5 Mounting Screws for Server Rack Cabinet | In Stock | £15.93 |
StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets | In Stock | £12.71 |
StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £33.51 |
StarTech.com Black Standard Universal Server Rack Cabinet Shelf | In Stock | £27.15 |
StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet | In Stock | £14.36 |
StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £29.51 |
StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £55.08 |
StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet | In Stock | £58.24 |
StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg | In Stock | £22.35 |
StarTech.com 1U Adjustable Mounting Depth Rack Mount Shelf - Heavy Duty Shelf - 175lbs / 80kg | In Stock | £63.41 |
StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - Heavy Duty - 250lbs / 113kg | In Stock | £80.98 |
StarTech.com 2U 22in Depth Fixed Rack Mount Shelf - 50lbs / 22kg | In Stock | £36.00 |
StarTech.com 2U 22in Vented Rack Mount Shelf – Fixed Server Rack Cabinet Shelf - 50lbs / 22kg | In Stock | £39.56 |
StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg | In Stock | £26.04 |
StarTech.com 2U Rack Mount Cantilever Shelf - Heavy Duty Fixed Server Rack Shelf - 125lbs / 56kg | In Stock | £44.60 |
