Add two Serial and two Parallel ports to your desktop system through a single PCI slot. The PCI2S2PMC 2S2P PCI Serial/Parallel Combo Card (16C1050 UART) adds 2 RS232 serial, and 2 IEEE-1284 Parallel ports to your system, through a PCI slot. Supporting RS232 speeds up to 115.2 Kbps and parallel rates up to 1.5 Mbps, the serial/parallel adapter offers the added connectivity needed for industrial and business applications, while only occupying a single 3.3/5V PCI slot. This 2S-2P card offers a broad operating system compatibility list that includes Windows? 7, Windows Server 2003, XP, DOS? and Linux, for simple integration into mixed environments.
- StarTech.com 2S2P PCI Serial Parallel Combo Card with 16C1050 UART - parallel/serial adapter - PCI
- Parallel/serial adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI
- 1.9 cm x 13.3 cm x 8.9 cm
- 200 g
- Data Link Protocol
- Parallel, serial
- System Requirements
- Microsoft DOS, Microsoft Windows 2000 / NT4.0, Microsoft Windows XP, Microsoft Windows 7, Linux 2.6.x, Microsoft Windows Vista, Windows 10 (32/64 bits)
- Limited lifetime warranty
- Form Factor
- Plug-in card
- PCI
- Connectivity Technology
- Wired
- Parallel, serial
- 2 - 25 pin D-Sub (DB-25) , 2 x serial - 9 pin D-Sub (DB-9)
- Compatible Slots
- 1 x PCI
- FCC, RoHS
- Software Included
- Drivers & Utilities
- OS Required
- 1.9 cm
- 13.3 cm
- 8.9 cm
- 200 g
- Limited warranty - lifetime
- 0 °C
- 85 °C
StarTech.com 6 ft RJ45 to DB9 Cisco Console Management Router Cable - M/F | In Stock | £21.42 |
StarTech.com DB9 RS232 Serial Null Modem Adapter - M/F | In Stock | £5.19 |
StarTech.com DB9 to DB25 Serial Cable Adapter - F/M | In Stock | £5.28 |
