StarTech.com 2s1p Serial Parallel Combo Mini PCI Express Card for Embedded Systems
Quicklinx: 7TGRWS00 Mfr#: MPEX2S1P552
Type: Parallel/serial adapter
Compatibility: PC
Interface: Mini PCI Express
£24.61 ex VAT
£29.53 inc VAT
Add two RS232 Serial Ports, and one Parallel Port to an Embedded System, through a mini PCI-Express Slot.
The MPEX2S1P552 2S1P Mini PCI Express Serial/Parallel Combo Card turns a mini-PCIe slot into two RS232 (DB9) serial ports, and one IEEE 1284 parallel port - a cost-saving solution for adding serial and parallel support to embedded systems that lack built-in serial/parallel functionality.
The 16650 UART adapter card features a native PCI Express single chip design, which enables you to take advantage of full PCI Express capability, by providing improved speed and reliability while reducing the load applied to the CPU by as much as 48% over conventional "bridge chip" serial cards .
StarTech.com 2s1p Serial Parallel Combo Mini PCI Express Card for Embedded Systems - parallel/serial adapter - 2 ports
Plug-in card
Interface (Bus) Type
Mini PCI Express
PCI Specification Revision
PCIe 1.1
3 cm x 5 cm x 1 cm
150 g
Ports Qty
2 ports
Auxiliary Ports
1 x parallel port
Parallel, serial
Data Transfer Rate
1.5 Mbps
MCS9901CV-CC - MosChip Semiconductor
Microsoft Windows 2000, Microsoft Windows Server 2008 R2, Linux Kernel 2.6.x, Microsoft Windows Vista (32/64 bits), Microsoft Windows CE 6.0, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits)
Parallel/serial adapter - 2 ports
Plug-in card
Mini PCI Express
PCIe 1.1
Wired
Parallel, serial
Auxiliary Ports
1 x parallel port
Data Transfer Rate
1.5 Mbps
Processor / Memory
1 x IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25) , 2 x RS-232 - 9 pin D-Sub (DB-9)
Compatible Slots
1 x Mini PCI Express - full-length
FCC, RoHS
3 cm
5 cm
1 cm
150 g
Limited warranty - lifetime
55 °C
5 - 95%
7TGR StarTech.com 6 ft Straight Through Serial Cable - DB9 F/F In Stock £3.65
7TGR StarTech.com 6ft Straight Through Serial Cable - DB9 M/F In Stock £3.51
7TGR StarTech.com 24in Internal USB Motherboard Header to Serial RS232 Adapter In Stock £17.07
7TGR StarTech.com 4 Port RS232 Mini PCI Express Serial Card with 16650 UART In Stock £69.47
Compatibility: PC
Price Range Ex VAT: 0 - 50
