StarTech.com 2S1P PCI Serial Parallel Combo Card with 16550 UART
Quicklinx: 3ZRNWS00 Mfr#: PCI2S1P
Type: Parallel/serial adapter
Compatibility: PC
Interface: PCI
  • Windows 8 (32/64 bits)
28 in stock
£26.29 ex VAT
£31.54 inc VAT
Add a parallel port and two RS-232 serial ports to your PC through a PCI expansion slot. The PCI2S1P PCI Serial/Parallel Combo Card turns a PCI slot into two external 16C550 serial ports and one external EPP/ECP parallel port - an all-in-one solution that gives you both parallel and serial connections while taking up only one PCI slot.
Suitable for installation in a small form factor computer, the PCI serial/parallel card includes an optional low profile/half-height mounting bracket that makes installation easy.
The serial/parallel combo card is PCI plug and play ready and supports IRQ sharing for fast, simple installation. The combo card is supported in virtually any Microsoft Windows operating environment (Windows 7, Server 2008 R2, Vista, XP, ME, 2000, 98, 95 and NT4).
StarTech.com 2S1P PCI Serial Parallel Combo Card with 16550 UART - IEEE 1284 Card - Serial Parallel PCI - PCI Serial Adapter (PCI2S1P) - parallel/serial adapter - 3 ports
Plug-in card
Interface (Bus) Type
PCI
Ports Qty
3 ports
Cabling Type
Parallel, serial
Data Transfer Rate
430 Kbps
Microsoft DOS, Linux, Microsoft Windows 2000, Microsoft Windows 95/98 Second Edition, Microsoft Windows XP Embedded, Microsoft Windows CE 5.0, Microsoft Windows Embedded POSReady 2009, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows CE 6.0, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
Parallel/serial adapter - 3 ports
Plug-in card
PCI
Wired
Cabling Type
Parallel, serial
Data Transfer Rate
430 Kbps
1 x RS-232 - 9 pin D-Sub (DB-9) - male - 1 , 1 x RS-232 - 25 pin D-Sub (DB-25) - male - 1 , 1 x IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25) - female - 1
Compatible Slots
1 x PCI
Software Included
Drivers & Utilities
Limited warranty - parts and labour - lifetime - carry-in
3ZRN StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/M In Stock £3.83
3ZRN StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/F In Stock £4.29
3ZRN StarTech.com 10 ft Cross Wired DB9 to DB25 Serial Null Modem Cable - F/M In Stock £3.90
3ZRN StarTech.com 6 ft Straight Through Serial Cable - DB9 F/F In Stock £3.69
3ZRN StarTech.com 6ft Straight Through Serial Cable - DB9 M/F In Stock £3.53
3ZRN StarTech.com 1 Port PCI Parallel Adapter Card In Stock £20.48
3ZRN StarTech.com 2S1P PCI Serial Parallel Combo Card with 16550 UART In Stock £26.29
3ZRN StarTech.com 2 Port PCI RS232 Serial Adapter Card with 16550 UART In Stock £19.51
3ZRN StarTech.com DB9 to DB25 Serial Cable Adapter - F/M In Stock £4.19
3ZRN StarTech.com DB9 to DB25 Serial Cable Adapter - F/F In Stock £4.10
Compatibility: PC
Interface: PCI
Price Range Ex VAT: 0 - 50
