StarTech.com 2S1P PCI Express Serial Parallel Combo Card with Breakout Cable
Quicklinx: 84NWWS00 Mfr#: PEX2S1P553B
Type: Parallel/serial adapter
Compatibility: Mac, PC
Interface: PCI Express x1
£26.02 ex VAT
£31.22 inc VAT
Add a parallel port and two RS-232 serial ports to your PC through a PCI-Express expansion slot. The PEX2S1P553B 2S1P PCI Express Serial Parallel Combo Card with Breakout Cable combines the functionality of Parallel and Serial cards, adding 2 RS232 serial ports and 1 parallel port through a single PCI Express (PCIe) slot. Suitable for almost any computer, the card offers a low profile/half-height design and includes an optional full-height bracket. The included break-out cable uses a single connector on the card to deliver 3 ports, avoiding crowded connections that can occur with fixed/static ports. Compatible with a broad range of operating systems including DOS, Windows? 7/Server 2008 R2/Vista/XP/Server 2003/2000/98SE (32/64 bit), Linux and Mac OS X. The card also features a native single-chip design that provides improved speed and reliability while reducing the CPU load by as much as 48% over conventional (bridge chip) cards.
StarTech.com 2S1P PCI Express Serial Parallel Combo Card with Breakout Cable - parallel/serial adapter - 2 ports
Plug-in card - low profile
Interface (Bus) Type
PCI Express x1
2.3 cm x 9.5 cm x 7.9 cm
50 g
Ports Qty
2 ports
Auxiliary Ports
1 x parallel port
RS-232
Microsoft DOS, Linux, Microsoft Windows 95/98 Second Edition, Microsoft Windows Server 2003, Apple MacOS X 10.4 or later, Microsoft Windows Server 2008 R2, Microsoft Windows 2000/XP/Vista/7
Parallel/serial adapter - 2 ports
PCI Express x1
Wired
RS-232
Auxiliary Ports
1 x parallel port
1 x IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25) (on cable) , 2 x RS-232 - 9 pin D-Sub (DB-9) (on cable)
Compatible Slots
1 x PCI Express x1 - low-profile
Full-height bracket
1 x serial / parallel cable (external)
WHQL, RoHS
2.3 cm
9.5 cm
7.9 cm
50 g
Limited warranty - lifetime
70 °C
5 - 85%
84NW StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/M In Stock £3.81
84NW StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/F In Stock £4.27
84NW StarTech.com 6 ft Straight Through Serial Cable - DB9 F/F In Stock £3.65
84NW StarTech.com 6ft Straight Through Serial Cable - DB9 M/F In Stock £3.51
84NW StarTech.com DB9 to DB25 Serial Cable Adapter - F/M In Stock £4.18
84NW StarTech.com DB9 to DB25 Serial Cable Adapter - F/F In Stock £4.08
84NW StarTech.com 2m Black DB9 Null Modem Cable In Stock £3.87
Compatibility: Mac
Compatibility: PC
Price Range Ex VAT: 0 - 50
