Add a parallel port and two RS-232 serial ports to your PC through a PCI-Express expansion slot. The PEX2S1P553B 2S1P PCI Express Serial Parallel Combo Card with Breakout Cable combines the functionality of Parallel and Serial cards, adding 2 RS232 serial ports and 1 parallel port through a single PCI Express (PCIe) slot. Suitable for almost any computer, the card offers a low profile/half-height design and includes an optional full-height bracket. The included break-out cable uses a single connector on the card to deliver 3 ports, avoiding crowded connections that can occur with fixed/static ports. Compatible with a broad range of operating systems including DOS, Windows? 7/Server 2008 R2/Vista/XP/Server 2003/2000/98SE (32/64 bit), Linux and Mac OS X. The card also features a native single-chip design that provides improved speed and reliability while reducing the CPU load by as much as 48% over conventional (bridge chip) cards.
- StarTech.com 2S1P PCI Express Serial Parallel Combo Card with Breakout Cable - parallel/serial adapter - 2 ports
- Parallel/serial adapter
- Form Factor
- Plug-in card - low profile
- Interface (Bus) Type
- PCI Express x1
- 2.3 cm x 9.5 cm x 7.9 cm
- 50 g
- Ports Qty
- 2 ports
- Auxiliary Ports
- 1 x parallel port
- Data Link Protocol
- RS-232
- System Requirements
- Microsoft DOS, Linux, Microsoft Windows 95/98 Second Edition, Microsoft Windows Server 2003, Apple MacOS X 10.4 or later, Microsoft Windows Server 2008 R2, Microsoft Windows 2000/XP/Vista/7
- Limited lifetime warranty
- Parallel/serial adapter - 2 ports
- Form Factor
- PCI Express x1
- Connectivity Technology
- Wired
- RS-232
- Auxiliary Ports
- 1 x parallel port
- 1 x IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25) (on cable) , 2 x RS-232 - 9 pin D-Sub (DB-9) (on cable)
- Compatible Slots
- 1 x PCI Express x1 - low-profile
- Included Accessories
- Full-height bracket
- Cables Included
- 1 x serial / parallel cable (external)
- WHQL, RoHS
- OS Required
- 2.3 cm
- 9.5 cm
- 7.9 cm
- 50 g
- Limited warranty - lifetime
- 0 °C
- 70 °C
- 5 - 85%
StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/M | In Stock | £3.81 |
StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/F | In Stock | £4.27 |
StarTech.com 10 ft Cross Wired DB9 to DB25 Serial Null Modem Cable - F/M | In Stock | £3.88 |
StarTech.com 6 ft Straight Through Serial Cable - DB9 F/F | In Stock | £3.65 |
StarTech.com 6ft Straight Through Serial Cable - DB9 M/F | In Stock | £3.51 |
StarTech.com DB9 to DB25 Serial Cable Adapter - F/M | In Stock | £4.18 |
StarTech.com DB9 to DB25 Serial Cable Adapter - F/F | In Stock | £4.08 |
StarTech.com 2m Black DB9 Null Modem Cable | In Stock | £3.87 |
