Upgrade your computer to the 10Gbps speed of USB 3.1 Gen 2, by adding two USB Type-C ports. Get ready for the future of universal connectivity and high-speed performance. This USB 3.1 card adds two USB-C ports to your desktop, with a combined bandwidth up to 10Gbps. With greater bandwidth, you can save time and avoid the performance bottlenecks often associated with other connectivity technologies.
Because the card offers USB Type-C ports, you can rest assured your computer is compatible with the growing popularity of USB-C peripherals.
By adding 10Gbps USB ports to your computer, you can harness the speed of USB 3.1 Gen 2. You can access peripherals at twice the speed of traditional USB 3.0 devices. (USB 3.0 is also known as USB 3.1 Gen 1.) The card delivers faster file transfer rates, so you can get more work done in less time.
With higher data throughput, this PCI Express USB 3.1 card is a necessity for external hard drives, , and many other USB 3.1 peripherals. Plus, the USB card integrates a SATA power connector to support high-powered devices, making it ideal for use with large external storage solutions.
Because it offers two USB-C ports, this innovative card enables you to connect the growing number of USB Type-C devices today, or in the near future.
USB-C connectors are small, reversible, and easy-to-use. You can reduce frustration and the risk of damage to your ports by connecting the plug with either side facing up, making insertions easier than past USB generations.
The card is backward compatible with USB 3.0 (5Gbps) and USB 2.0 (480mbps) devices. You can add the card now in preparation for future devices, while still connecting your existing USB peripherals using a variety of .
The PCIe USB-C card comes equipped with a full-profile bracket, but also includes a half-height or low-profile bracket, making it easy to install in full or small form-factor desktops or servers. And, the card offers hassle-free installation, with no additional software or drivers required in many natively supported operating systems.
The card does not support DP Alt Mode or USB Power Delivery.
Work faster, with USB 3.1 performance
By adding 10 Gbps USB ports to your computer, you can harness the speed of USB 3.1. The card delivers faster file transfer rates, so you can get more work done in less time. With higher data throughput, this PCI Express USB 3.1 card is a necessity for external hard drives, hard drive enclosures, and many other USB 3.1 peripherals. Plus, the USB card integrates a SATA power connector to support high-powered devices, making it ideal for use with large external storage solutions. -
Help future proof your computer, with USB-C
Because it offers two USB-C ports, this alternative card enables you to connect the growing number of USB Type C devices today, or in the near future. USB-C connectors are small, reversible, and easy-to-use. You can reduce frustration and the risk of damage to your ports by connecting the plug with either side facing up, making insertions easier than past USB generations.
- StarTech.com 2-Port USB 3.1 (10Gbps) Card - 2x USB-C - PCIe - USB adapter - PCIe x4 - USB-C 3.1 Gen 2 x 2
- USB adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI Express x4
- Ports
- 1.8 cm x 12 cm x 9.2 cm
- 116 g
- Data Link Protocol
- USB 3.1
- Data Transfer Rate
- 10 Gbps
- Processor
- ASMedia ASM1142
- USB 3.0, xHCI
- System Requirements
- Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Apple MacOS X 10.9 or later, Microsoft Windows 7 / 8 / 8.1 / 10, Linux 3.5
- 2-year warranty
- Designed For
- P/N: CFASTRWU3C, FCREADU3C, HB30C3A1GE, HB30C3A1GEA, HB30C3AGEPD, ICUSBCPLLD25, S251BU31315, S251BU31C3CB, SDMSDRWU3AC, USB31CSAT3CB
- USB adapter
- Form Factor
- Plug-in card
- PCI Express x4
- Ports
- Connectivity Technology
- Wired
- USB 3.1
- 10 Gbps
- USB Attached SCSI Protocol (UASP)
- USB 3.0, xHCI
Processor / Memory
- Processor
- ASMedia ASM1142
- 2 x USB 3.1 - 24 pin USB-C , 1 x SATA 3Gb/s - 15 pin Serial ATA power (internal)
- Included Accessories
- Low-profile bracket
- FCC, RoHS, WEEE, RCM
- OS Required
- 1.8 cm
- 12 cm
- 9.2 cm
- 116 g
- Limited warranty - 2 years
- 5 °C
- 50 °C
- Designed For
