Brand
StarTech.com 2Port USB 3.1 10Gbps Card PCIe
Quicklinx: BX2VWS00 Mfr#: PEXUSB311EI
Wired / Wireless: Wired
Protocol: USB 3.1
Compatibility: PC
Type: USB adapter
Hurry, only 1 left in stock!
£36.50 ex VAT
£43.80 inc VAT
Upgrade your computer to the faster speed of USB 3.1 Gen 2, by adding one external and one internal 10Gbps USB Type-A ports. This USB 3.1 Gen 2 card prepares you for the next generation of USB performance, on the inside and outside of your computer. The 2-port card adds one internal Type-A connector as well as one external Type-A connector to your desktop computer, with a combined bandwidth of up to 10Gbps. For power-hungry devices, the card also has an internal SATA power connector, enabling you to use your computer's power supply to add more power to the ports.
With greater bandwidth, you can save time and avoid the performance bottlenecks that are often associated with other connectivity technologies.
With an internal port, you can connect internal devices that use a USB Type-A connector, such as a front-bay SD card reader. Plus, you can use the internal port to keep peripherals safely inside your computer case - perfect for high-capacity USB flash drives or interface devices used for external wireless peripherals such as keyboards and mice or Bluetooth adapters.
The card also features an external port that can be used for any USB Type-A device, like your external hard drive or any wired peripheral.
By adding 10Gbps USB ports to your computer, you can harness the speed of USB 3.1 Gen 2 and rest assured that you're ready for both current and future high-bandwidth USB-A devices.
With higher data throughput, this PCI Express USB 3.1 card is a necessity for external hard drives, , and many other USB 3.1 peripherals. Plus, the USB card integrates a SATA power connector to support high-powered devices, making it ideal for use with large external storage solutions.
For more flexibility, you can couple the card with a USB31AC1M USB-C to USB-A cable (USB31AC1M) and connect your USB Type-C devices.
Connecting your older peripherals isn't a problem. This versatile USB 3.1 Gen 2 (10Gbps) card is backward compatible with legacy USB 3.0 and 2.0 devices that use the common USB Type-A port, so you can eliminate the added expense and aggravation of purchasing new devices.
For a hassle-free installation with no additional software or drivers required, the card is natively supported by most operating systems, and interfaces with the PCI Express 3.0 x4 slot on your computer. Plus, the high-quality card includes both standard-profile and low-profile (half-height) brackets, making it easy to install in full or small form-factor PCs or servers.
StarTech.com 2 Port USB 3.1 (10Gbps) Card - USB-A 1x External 1x Internal - PCIe USB 3.1 Card with Type-A - PCI Express (PEXUSB311EI) - USB adapter - PCIe x4 - USB 3.1 x 2
USB adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express x4
Ports
USB 3.1 x 2
1.8 cm x 12 cm x 9 cm
50 g
USB 3.1
Data Transfer Rate
10 Gbps
ASMedia ASM1142
xHCI, USB 3.1
Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Apple MacOS X 10.9 or later, Microsoft Windows 7 / 8 / 8.1 / 10, Linux 3.5
P/N: USB312SAT3, USB31C2SAT3
USB adapter
PCI Express x4
Ports
USB 3.1 x 2
Wired
USB 3.1
Data Transfer Rate
10 Gbps
USB Attached SCSI Protocol (UASP)
xHCI, USB 3.1
Processor / Memory
ASMedia ASM1142
1 x USB 3.1 - 24 pin USB-C (external) , 1 x USB 3.1 - 24 pin USB-C (internal) , 1 x SATA 3Gb/s - 15 pin Serial ATA power
Low-profile bracket
FCC, RoHS, WEEE, RCM
1.8 cm
12 cm
9 cm
50 g
5 °C
50 °C
BX2V StarTech.com 6in 4 Pin Molex to SATA Power Cable Adapter In Stock £3.11
BX2V StarTech.com 4 Port PCI Express (PCIe) SuperSpeed USB 3.0 Card Adapter w/ 4 Dedicated 5Gbps Channels In Stock £79.51
BX2V StarTech.com 2m (6ft) Slim SuperSpeed USB 3.0 A to Micro B Cable - M/M In Stock £11.01
BX2V StarTech.com 7 Port SuperSpeed USB 3.0 Hub - Desktop USB Hub with Power Adapter – Black In Stock £46.11
BX2V StarTech.com 7 Port USB 3.0 Hub Desktop In Stock £58.00
BX2V StarTech.com 7 Port PCIe USB 3.0 Card In Stock £57.06
BX2V StarTech.com 4 Port PCIe USB 3.0 Card In Stock £27.92
BX2V StarTech.com 4 Port PCIe USB 3.0 Card In Stock £26.34
BX2V StarTech.com USB 3.1 Enclosure for 2.5" SSD In Stock £25.04
BX2V StarTech.com 1m USB 3.1 USB-C to USB-A Cbl In Stock £9.82
BX2V StarTech.com USB 3.1 Tool-free Enclosure In Stock £23.36
BX2V StarTech.com USB 3.1 Gen 2 Enclosure In Stock £39.96
BX2V StarTech.com 2Port USB 3.1 10Gbps Card PCIe In Stock £36.50
BX2V StarTech.com 4 Port USB Adaptor PCI Express USB 3.1 Gen 2 Controller Card - 3xA + 1xC In Stock £78.33
BX2V StarTech.com StarTech.com 2-Port 10Gbps USB-A/USB-C PCIe Card -USB 3.1 In Stock £38.45
BX2V StarTech.com 2-Port USB 3.2 Gen 2 PCIe Card - USB-A SuperSpeed 10Gbps PCI Express 3.0 x2 In Stock £23.32
BX2V StarTech.com 4-Port USB 3.2 Gen 2 PCIe Card - USB-A SuperSpeed 10Gbps PCI Express 3.0 x4 In Stock £83.55
BX2V StarTech.com 1-Port USB 3.2 Gen 2x2 PCIe Card - USB-C SuperSpeed 20Gbps PCI Express 3.0 x4 In Stock £41.19
BX2V StarTech.com 5-Port USB PCIe Card In Stock £55.35
BX2V StarTech.com 4-Port USB PCIe Card In Stock £114.87
Protocol: USB 3.1
Compatibility: PC
Type: USB adapter
Stock Status: In stock
