StarTech.com 2m White USB 2.0 Extension Cable A to A - M/F
Quicklinx: 8ZD1WS00 Mfr#: USBEXTPAA2MW
Length: 2m
More than 50 in stock
£5.51 ex VAT
£6.61 inc VAT
Extend the length of your USB 2.0 cable by up to 2m. The USBEXTPAA2MW 2m White USB 2.0 Extension Cable features a USB ''A'' male connector and a USB ''A'' female connector, enabling you to extend the connection distance between your USB 2.0 devices by up to 1-meter - allowing for better placement of your peripheral devices, or adding flexibility to your existing USB ports.
The cable features thin USB connector moldings which allow you to simplify your connections, and plug into tight fitting locations.
StarTech.com 2m White USB 2.0 Extension Cable Cord - A to A - USB Male to Female Cable - 1x USB A (M), 1x USB A (F) - White, 2 meter (USBEXTPAA2MW) - USB extension cable - USB to USB - 2 m
USB extension cable
Double shielded
Molded, strain relief
Length
2 m
Connector
4 pin USB Type A - female
Connector (Second End)
4 pin USB Type A - male
USB / USB 2.0
White
P/N: MSDREADU2OTG, USBEXTPAA1MW, USBEXTPAA3MW, USBPAUB1MW, USBPAUB2MW, USBPAUB50CMW, UUSBOTG
USB extension cable
Double shielded
American Wire Gauge (AWG)
24/28
Plated Connector
Nickel
Length
2 m
White
Connector
USB / USB 2.0, RoHS
8ZD1 StarTech.com 3m White USB 2.0 Extension Cable A to A - M/F In Stock £5.94
8ZD1 StarTech.com 1m White USB 2.0 Extension Cable A to A - M/F In Stock £5.05
8ZD1 StarTech.com 2m White USB 2.0 Extension Cable A to A - M/F In Stock £5.51
8ZD1 StarTech.com 1m White Micro USB Cable - A to Micro B In Stock £2.92
8ZD1 StarTech.com 2m White Micro USB Cable - A to Micro B In Stock £6.73
Length: 2m
Stock Status: In stock
