StarTech.com 2m USB C to HDMI Cable - White
Quicklinx: D9T1WS00 Mfr#: CDP2HD2MWNL
Select:
StarTech.com 2m (6 ft.) USB-C to HDMI Cable - 4K at 60Hz
  • Clutter-free installation
    While this white adapter looks great next to computers that match the look and feel of laptops like your MacBook or HP Envy, it works with any USB-C computer that supports HDMI. At 2 m (6 ft.) in length, this adapter cable delivers a direct connection that eliminates excess adapters and cabling, ensuring a tidy and professional installation.
  • Astonishing picture quality
    At four times the resolution of high-definition 1080p, you'll be amazed at the picture quality of a 4K 60 Hz monitor or television. This adapter cable lets you harness the video capabilities that are built into your USB Type-C connection, to deliver the astonishing quality of Ultra HD to your 4K display. Plus, the adapter is still compatible with lower display resolutions, such as 1080p, which makes it a great accessory for your current home, office or other HD work environment, while future-proofing for 4K 60 Hz implementation.
StarTech.com 6ft (2m) USB C to HDMI Cable, 4K 60Hz USB Type C to HDMI 2.0 Video Adapter Cable, Thunderbolt 3 Compatible, Laptop to HDMI Monitor/Display, DP 1.2 Alt Mode HBR2 Cable, White - 4K USB-C Video Cable (CDP2HD2MWNL) - external video adapter - VL100 - white
External video adapter
Bus Type
USB-C
Graphics Engine
VL100
Max Resolution
3840 x 2160
HDMI (male connector)
2.2 cm 1.4 cm
Length
2 m
Enclosure Colour
White
3-year warranty
P/N: TB4CDOCK
Bus Type
USB-C
Graphics Engine
VL100
Max Resolution
3840 x 2160 at 60 Hz
HD/4k Ready, 7.1 channel surround sound ready, Thunderbolt 3 compatible
FCC, RoHS, WEEE
2.2 cm
1.4 cm
Length
2 m
80 g
Enclosure Colour
White
Limited warranty - 3 years
45 °C
5 - 90% (non-condensing)
P/N: TB4CDOCK
D9T1 StarTech.com USB-C to DisplayPort Adapter Cable 1m (3 ft.) - 4K at 60 Hz In Stock £32.27
D9T1 StarTech.com 2m USB-C to HDMI Cable In Stock £31.44
D9T1 StarTech.com 2m USB C to HDMI Cable - Black In Stock £27.71
D9T1 StarTech.com 1m USB C to HDMI Cable - Black In Stock £27.65
D9T1 StarTech.com 3m USB C to HDMI Cable - Black In Stock £28.99
D9T1 StarTech.com 1m USB C to HDMI Cable - White In Stock £24.31
D9T1 StarTech.com 3m USB-C to DVI Cable - Black In Stock £25.34
D9T1 StarTech.com 3m USB C to VGA Cable - Black In Stock £30.07
D9T1 StarTech.com USB-C to HDMI Adapter with HDR - 4K 60Hz - Black - USB Type C to HDMI Converter In Stock £19.81
D9T1 StarTech.com USB C to HDMI Adapter 4K 60Hz In Stock £19.65
