StarTech.com 2m USB C to HDMI Cable - Black
Quicklinx: D9KGWS00 Mfr#: CDP2HD2MBNL
Length: 2m
Select:
Hurry, only 1 left in stock!
£27.71 ex VAT
£33.25 inc VAT
Express delivery Order within the next 21 hours for delivery on Friday
Create a clutter free workstation by connecting your USB-C computer directly to a HDMI display, without additional adapters. This USB-C to HDMI adapter cable offers a convenient solution for directly connecting your DisplayPort over USB Type-C device to your HDMI monitor, television, or projector. The adapter offers a connection distance of up to 2 m (6 ft.) and works with USB-C devices that support DP Alt Mode, such as the MacBook, Chromebook Pixel and Dell XPS models 15 and 13. It's also compatible with Thunderbolt 3 ports.
At 2 m (6 ft.) in length, this adapter cable delivers a direct connection that eliminates excess adapters and cabling, ensuring a tidy, professional installation.
For shorter and longer installations, StarTech.com also offers a 1 m (3 ft.) USB-C to HDMI cable (CDP2HD1MBNL) and a 3 m (10 ft.) USB-C to HDMI cable (CDP2HD3MBNL), enabling you to choose the right cable length for your custom installation needs.
At four times the resolution of high-definition 1080p, you'll be amazed at the picture quality of a 4K 60Hz monitor or television. This adapter cable lets you harness the video capabilities that are built into your USB Type-C connection, to deliver the astonishing quality of Ultra HD to your 4K display.
Plus, the adapter is still compatible with lower display resolutions, such as 1080p, which makes it a great accessory for your current home, office or other HD work environment, while future-proofing for 4K 60Hz implementation.
StarTech.com 6ft (2m) USB C to HDMI Cable, 4K 60Hz USB Type C to HDMI 2.0 Video Adapter Cable, Thunderbolt 3 Compatible, Laptop to HDMI Monitor/Display, DP 1.2 Alt Mode HBR2 Cable, Black - 4K USB-C Video Cable (CDP2HD2MBNL) - adapter cable - HDMI / USB - 2 m
Cable
Adapter cable - HDMI / USB
Max Output Resolution
3840 x 2160 - 60 Hz
Length
2 m
Connector
24 pin USB-C - male (input)
Connector (Second End)
HDMI - male (output)
Displayport 1.2/Thunderbolt 3
4K60Hz (3840 x 2160) support
3-year warranty
P/N: TB4CDOCK
Cable Type
Adapter cable 4K60Hz (3840 x 2160) support
Interface Supported
HDMI / USB
Length
2 m
HBR2 audio support, DisplayPort Alternate Mode support, 7.1 channel Surround Sound
Adapters & Converters
3840 x 2160
Refresh Rate
60 Hz
Apple MacOS, Linux, Android, Google Chrome OS, Windows 10, Apple iPadOS
Connector
19 pin HDMI Type A - male (output)
FCC, RoHS, HDCP 2.2, HDCP 1.4
55 g
Shipping Width
12.5 cm
Shipping Depth
22.5 cm
Shipping Weight
63 kg
Limited warranty - 3 years
P/N: TB4CDOCK
D9KG StarTech.com USB-C to DisplayPort Adapter Cable 1m (3 ft.) - 4K at 60 Hz In Stock £32.27
D9KG StarTech.com 2m USB-C to HDMI Cable In Stock £31.44
D9KG StarTech.com 2m USB C to HDMI Cable - Black In Stock £27.71
D9KG StarTech.com 1m USB C to HDMI Cable - Black In Stock £27.65
D9KG StarTech.com 3m USB C to HDMI Cable - Black In Stock £28.99
D9KG StarTech.com 1m USB C to HDMI Cable - White In Stock £24.31
D9KG StarTech.com 3m USB-C to DVI Cable - Black In Stock £25.34
D9KG StarTech.com 3m USB C to VGA Cable - Black In Stock £30.07
D9KG StarTech.com 3ft (1m) USB C to HDMI Cable 4K 60Hz /HDR10 - USB-C to HDMI In Stock £20.34
D9KG StarTech.com 6ft (2m) USB C to HDMI Cable 4K 60Hz / HDR10 - USB-C to HDMI In Stock £22.07
D9KG StarTech.com 9.8ft (3m) USBC to HDMI Cable 4K USB-C HDMI Media Convertor In Stock £27.75
D9KG StarTech.com 13ft (4m) USB C to HDMI Cable 4K HDMI USB-C to HDMI Monitor In Stock £31.53
D9KG StarTech.com 16ft (5m) USB C to HDMI Cable 4K USB-C to HDMI Monitor Conve In Stock £34.12
Length: 2m
