StarTech.com 2m USB 2.0 C to Micro B Cable
Quicklinx: CTWJWS00 Mfr#: USB2CUB2M
£12.66 ex VAT
£15.19 inc VAT
Charge and sync your USB 2.0 Micro-B devices from a USB-C host, over longer distances. This USB-C to Micro-B cable lets you charge and sync a USB 2.0 Micro-USB mobile device from a USB Type-C laptop. You can also charge your device using a USB-C wall charger, car charger or power bank, or connect an external Micro-USB drive for easy data backups.
The 2-meter cable gives you the length you need to overcome distance restrictions and stay connected. You can charge and sync your Micro-USB mobile device, in almost any environment. Even while you're taking notes in a boardroom, catching up on emails in your hotel room, or reading in a coffee shop, the connection to your mobile device will reach your computer or wall charger more comfortably.
You can also use the USB-C to Micro-USB cable to back up data to an external Micro-USB 2.0 drive from your USB-C or Thunderbolt 3 computer.
The longer cable lets you organize your desk to match your needs, enabling you to connect your device up to 2-meters away from your computer.
StarTech.com USB C to Micro USB Cable 2m 6ft - USB-C to Micro USB Charge Cable - USB 2.0 Type C to Micro B - Thunderbolt 3 Compatible (USB2CUB2M) - USB-C cable - 24 pin USB-C to Micro-USB Type B - 2 m
USB-C cable
Shielded
Length
2 m
Connector
24 pin USB-C - male
Connector (Second End)
5 pin Micro-USB Type B - male
USB / USB 2.0
USB-C cable
Shielded
Shielding Material
Jacket Material
PVC
American Wire Gauge (AWG)
22/30
Plated Connector
Nickel
Length
2 m
58 g
Connector
24 pin USB-C - male
USB / USB 2.0, RoHS, WEEE
CTWJ StarTech.com 1m USB 2.0 C to Micro-USB Cable In Stock £9.63
CTWJ StarTech.com 2m USB 2.0 C to Micro B Cable In Stock £12.66
CTWJ StarTech.com 0.5m USB 2.0 C Micro-B Cable In Stock £8.61
