StarTech.com 2m Multimode 50/125 Duplex Fiber Patch Cable LC - ST
Quicklinx: 8M47WS00 Mfr#: 50FIBLCST2
Length: 2m
Colour: Orange
Stock Status: In Stock, Used Stock
4 in stock
£6.21 ex VAT
£7.45 inc VAT
Standard delivery Delivered within 3-5 working days
Connect fiber network devices for high-speed transfers with LSZH rated cable. The 50FIBLCST2 2m LSZH LC to ST Fiber Cable features 50/125 micron fiber for high-speed, high bandwidth data transmissions over Gigabit Ethernet and Fiber Channel networks, with support for duplex multimode applications.
This LC-ST patch cable is housed in a LSZH (Low-Smoke, Zero-Halogen) flame retardant jacket, to ensure minimal smoke, toxicity and corrosion when exposed to high sources of heat, in the event of a fire. Making it ideal for use in industrial settings, central offices and schools, as well as residential settings where building codes are a consideration.
Each Duplex 50/125 (OM2) Multimode Fiber Patch Cable is individually tested and certified to be within acceptable optical insertion loss limits for guaranteed compatibility and 100% reliability.
StarTech.com 2m Fiber Optic Cable - Multimode Duplex 50/125 - LSZH - LC/ST - OM2 - LC to ST Fiber Patch Cable - patch cable - 2 m - orange
Patch cable - OM2
Duplex fibre optic
Type of Fibre Optics
Multimode
Molded
Length
2 m
Core / Cladding Diameter
50 / 125 micron
Connector
2 x ST multi-mode - male
Connector (Second End)
2 x LC multi-mode - male
Orange
P/N: MCM1110MMLC
Network Cable Type
Patch cable - OM2
Duplex fibre optic
Multimode
Jacket Material
Low Smoke Zero Halogen (LSZH)
Fibre Qty
2
50 / 125 micron
Molded
Length
2 m
Orange
Connector
RoHS
P/N: MCM1110MMLC
8M47 StarTech.com 10m Multimode 50/125 Duplex Fiber Patch Cable LC - ST In Stock £18.85
8M47 StarTech.com 2m Multimode 50/125 Duplex Fiber Patch Cable LC - ST In Stock £6.21
8M47 StarTech.com 5m Multimode 50/125 Duplex Fiber Patch Cable LC - ST In Stock £14.51
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: 8M47 042722
Condition: Customer return - item has been used and shows signs of use
This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  £1.02
Ref: 8M47 042723
Condition: Customer return - item has been used and shows signs of use. PLEASE NOTE. Not in original packaging
This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is not present or functional  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  £1.02
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Length: 2m
Colour: Orange
Stock Status: Used Stock
Price Range Ex VAT: 0 - 50
