Brand
StarTech.com 2m Mini DisplayPort 1.2 Cable M/M - Mini DisplayPort 4k
Quicklinx: 80HBWS00 Mfr#: MDISP2M
Length: 2m
15 in stock
£12.75 ex VAT
£15.30 inc VAT
Create a high-resolution 4k x 2k connection with HBR2 support between your Mini DisplayPort-equipped laptop and monitor. The MDISP2M 2m Mini DisplayPort 1.2 cable features 2 Mini DP male connectors, and offers a dependable solution for connecting any Mini DisplayPort-enabled laptop (including Mac family of products) to a Mini DisplayPort-equipped monitor.
The mDP cable supports high resolutions of up to 4k x 2k (3840 x 2160) @ 60Hz with a maximum HBR2 bandwidth of 21.6 Gbps. The cable also supports Multi-Stream (MST) for daisy chaining multiple monitors and provides optional audio support.
Newer laptop and desktop computers (e.g. Apple) come equipped with Thunderbolt ports only. The Mini DisplayPort Cables can be connected to the Thunderbolt ports, enabling you to connect your Mini DP compatible displays.
StarTech.com 2m Mini DisplayPort 1.2 Cable M/M Mini DisplayPort 4k - DisplayPort cable - 2 m
DisplayPort cable
Shielded
Length
2 m
Connector
Mini DisplayPort - male
Connector (Second End)
RoHS
DisplayPort cable
Shielded
Shielding Material
American Wire Gauge (AWG)
32
Plated Connector
Nickel
Length
2 m
Connector
RoHS
80HB StarTech.com 6in DisplayPort to Mini DisplayPort Video Cable Adapter - M/F In Stock £8.26
80HB StarTech.com Mini DisplayPort to DisplayPort Adapter Converter - M/F In Stock £22.37
80HB StarTech.com 1m Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £8.40
80HB StarTech.com 2m Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £9.49
80HB StarTech.com 2m Mini DisplayPort 1.2 Cable M/M - Mini DisplayPort 4k In Stock £12.75
80HB StarTech.com 1m Mini DisplayPort 1.2 Cable M/M - Mini DisplayPort 4k In Stock £12.17
Length: 2m
Stock Status: In stock
