Product
Brand
StarTech.com 2m Micro USB 3.0 Cable - M/M
Quicklinx: C7C4WS00 Mfr#: USB3AUB2MB
This USB 3.1 Gen 1 (5Gbps) cable, also known as a USB 3.0 cable, is built to exact specifications and is fully tested to ensure maximum performance. It provides a dependable and cost-effective solution for connecting your Micro-USB 3.0 devices.
At 2 meters (6 feet) in length, this longer USB cable overcomes the distance restrictions of more common designs and lets you organize your desk and your office to match your needs by enabling you to place your Micro-USB devices further away from your PC or laptop. And, if you're using it as a charging cable for your mobile devices, it lets you stay connected even while you're taking notes in a boardroom, catching up on emails in a hotel room, or reading in a coffee shop.
StarTech.com Micro USB 3.0 Cable - M/M - USB cable - 2 m
USB cable
Double shielded
Length
2 m
Connector
9 pin USB Type A - male
Connector (Second End)
10 pin Micro-USB Type B - male
USB 3.0
USB cable
Double shielded
Shielding Material
Jacket Material
PVC
American Wire Gauge (AWG)
24/28
Plated Connector
Nickel
Length
2 m
90 g
Connector
USB 3.0, RoHS
