StarTech.com 2m Left Angle High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable - HDMI to HDMI M/M
Quicklinx: 8HMWWS00 Mfr#: HDMM2ML
Create Ultra HD connections between your High Speed HDMI-equipped devices, even in hard to reach areas and tight spaces. The HDMM2ML High Speed HDMI cable (2m/6.5ft) features an HDMI male connector on one end and a left-angled connector on the other, for a dependable connection between HDMI-enabled devices even with limited space around a device's HDMI port. The left-angled HDMI connector allows the shaft of the cable to fit neatly against a device's HDMI port, in such a way as to minimize the space required near the connection point, which helps make installation easier in narrow spaces and reduces strain on the connection.
This high quality HDMI cable fully supports 1080p+ resolutions at up to 120Hz refresh rate, with life-like color. To accommodate the demands of future high definition devices, such as increased resolutions and higher frame rates, this Ultra HD cable supports resolutions up to 4k x 2k.
StarTech.com High Speed HDMI digital video and audio cables are expertly designed and constructed of only top quality materials to ensure high quality, high definition performance. The HDMI standard combines high bandwidth video and multi-channel digital audio into a single cable, and provides crystal clear image resolution.
StarTech.com High Speed Left Angle HDMI Cable - HDMI cable - 2 m
Cable
HDMI cable
Shielded
American Wire Gauge (AWG)
28
Length
2 m
Connector
HDMI - male
Connector (Second End)
HDMI - male
Angled connector
Cable Type
HDMI cable - angled connector
Shielded
28
Jacket Material
PVC
Shielding Material
Length
2 m
Plated Connector
Gold
Moulded, strain relief
Connector
19 pin HDMI Type A - male
RoHS
Limited warranty - lifetime
