Extend the connection distance between your HDMI-enabled devices by 2 meters. The HDEXT2M HDMI extension cable (2m) features an HDMI 19-pin (male) connector on one end and an HDMI 19-pin (female) connector on the other, providing an extra 2-meter connection distance between your HDMI-enabled devices.
This high quality HDMI cable fully supports 1080p+ resolutions at up to 120Hz refresh rate, with life-like color. To accommodate the demands of future high definition devices, such as increased resolutions and higher frame rates, this Ultra HD cable supports resolutions up to 4k x 2k.
StarTech.com High Speed HDMI extension cables are expertly designed and constructed of only top quality materials to ensure high quality, high-definition performance. The HDMI standard combines high bandwidth video and multi-channel digital audio into a single cable, and provides crystal clear image resolution.
- StarTech.com 2m HDMI Extension Cable - Ultra HD 4k x 2k HDMI Cable M/F - 2m HDMI Extension - HDMI Male Female Cable - HDMI Extension cord (HDEXT2M) - HDMI extension cable - 2 m
- Cable
- Technology
- Shielded
- American Wire Gauge (AWG)
- 28
- Length
- 2 m
- Black
- Connector
- HDMI - male
- Connector (Second End)
- HDMI - female
- Limited lifetime warranty
- Designed For
- P/N: CDP2HDMM2MB, DP2HDMM2MB, HDDVIMM3, HDMIDVIMM10, HDMIDVIMM6, HDMM10, HDMM12, HDMM15, HDMM1MP, HDMM25, HDMM2M, HDMM2MP, HDMM3, HDMM3MP, HDMM50, HDMM50A, HDMM6, HDPMM50, MDP2HDMM2MB
- Cable Type
- Technology
- Shielded
- 28
- Jacket Material
- PVC
- Shielding Material
- Aluminum mylar foil with braid
- Length
- 2 m
- Plated Connector
- Gold
- Black
- Connector
- 19 pin HDMI Type A - male
- 19 pin HDMI Type A - female
- Limited warranty - lifetime
- Designed For
