StarTech.com 2m Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M
Quicklinx: 85F7WS00 Mfr#: MXTMMHQ2M
Type: VGA
Length: 2m
More than 50 in stock
£6.20 ex VAT
£7.44 inc VAT
Connect your VGA monitor with the highest quality connection available. The MXTMMHQ2M High Resolution VGA Cable (2-meter) is designed to provide the highest video quality possible through VGA, ideally suited for high resolution applications of 1920x1200 and above.
This durably constructed coaxial VGA video cable (HD15 to HD15) eliminates the picture "ghosting" and fuzzy images that are inherent to non-coaxial VGA cables, while delivering superior EMI interference protection by using ferrite cores near the connector ends.
StarTech.com 2m Coax High Resolution Monitor VGA Video Cable HD15 M/M - VGA cable - 2 m
VGA cable
Triple shielded twisted pair coaxial
Molded
Length
2 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - male
RoHS
VGA cable
Shielding Material
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Molded
Length
2 m
Connector
RoHS
85F7 StarTech.com Slimline Adapter HDDB15 F/F In Stock £4.38
85F7 StarTech.com Right Angle VGA to VGA Cable Adapter Type 1 - M/F In Stock £6.09
85F7 StarTech.com 10m Coax High Resolution Monitor VGA Cable - HD15 M/M In Stock £23.03
85F7 StarTech.com 15m Coax High Resolution Monitor VGA Cable - HD15 M/M In Stock £36.43
85F7 StarTech.com 20m Coax High Resolution Monitor VGA Cable - HD15 M/M In Stock £49.74
85F7 StarTech.com 1m Monitor VGA Cable In Stock £5.11
85F7 StarTech.com 0.5m Coax High Resolution Monitor VGA Video Cable - HD15 M/M In Stock £5.22
85F7 StarTech.com 2m Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £6.20
85F7 StarTech.com 3m Coax High Resolution Monitor VGA Video Cable - HD15 to HD15 M/M In Stock £8.05
Type: VGA
Length: 2m
Price Range Ex VAT: 0 - 50
