StarTech.com 2m Black DB9 Null Modem Cable
Quicklinx: B14BWS00 Mfr#: SCNM9FF2MBK
Length: 2m
Select:
More than 50 in stock
£3.87 ex VAT
£4.64 inc VAT
Connect your serial devices, and transfer your files. The SCNM9FF2MBK 2m DB9 Null Modem Cable features two DB9 female connectors, allowing you to connect a serial device to a 9-pin serial port, or transfer files directly from PC to PC via a serial connection.
StarTech.com 2m Black DB9 RS232 Serial Null Modem Cable F/F - null modem cable - 2 m
Null modem cable
Molded, thumbscrews, EMI protection
Length
2 m
Connector
9 pin D-Sub (DB-9) - female
Connector (Second End)
Null modem cable
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Length
2 m
Connector
RoHS
Length: 2m
Price Range Ex VAT: 0 - 50
