StarTech.com 2m Black Cat6a Cable STP
Quicklinx: CZBSWS00 Mfr#: 6ASPAT2MBK
Length: 2m
Colour: Black
12 in stock
£8.67 ex VAT
£10.40 inc VAT
Express delivery Order within the next 21 minutes for delivery on Monday
Deliver high-performance 10 Gigabit network connections, free of noise and EMI/RFI interference. This Cat6a cable meets or exceeds all Category 6a cable specifications to ensure reliable 10Gb network connections. The cable is shielded to protect your network against electromagnetic interference (EMI/RFI) and system noise, providing the perfect solution for fast and safe network connections.
This 2-meter black patch cable is perfect for standard applications such as connecting from a wall jack to your laptop docking station or desktop computer.
For easier network installations, the Cat6a patch cables are available in a wide variety of lengths and colors. This ensures you have the right size of cable available when you need it and it lets you color code your connections for a more organized setup.
Each cable is tested for up to 500MHz frequency and is more than suitable for 10GBase-T Ethernet networks.
Constructed with 100% copper and foil-shielded, twisted-pair wiring, this cable was built for quality performance. The cable is designed to keep the data signals traveling through your network free from interference and is perfect in environments that are prone to large amounts of EMI.
The 50-micron gold connectors deliver optimum conductivity and eliminate signal loss due to oxidation or corrosion.
For trouble-free cable runs, this durable cable features snagless connectors that protect the RJ45 clips during installation, making them less likely to snag or break.
The cable also features molded boots which offer connector strain relief by stopping the RJ45 connector termination points from bending at sharp angles. This reduces the risk of damage to the cable, which could decrease network connectivity and performance.
StarTech.com 2m Black Cat6a / Cat 6a Shielded Ethernet Patch Cable 2 m - patch cable - 2 m - black
Patch cable - CAT 6a
Shielded twisted pair (STP)
Shielding Material
Aluminium-polyester foil
Wires per Cable
8 wires
Molded, snagless, strain relief, PoE ready, RFI/EMI shielding
Length
2 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Network Cable Type
Shielding Material
Jacket Material
PVC
American Wire Gauge (AWG)
25
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
2 m
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 500 MHz
CZBS StarTech.com 2m Aqua Cat6a Cable STP In Stock £8.67
CZBS StarTech.com 2m Black Cat6a Cable STP In Stock £8.67
CZBS StarTech.com 2m Blue Cat6a Cable STP In Stock £8.67
CZBS StarTech.com 2m Gray Cat6a Cable STP In Stock £8.67
Length: 2m
Colour: Black
Price Range Ex VAT: 0 - 50
