StarTech.com 2m (6ft) Long White Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad
Quicklinx: 8T5LWS00 Mfr#: USBLT2MW
Length: 2m
Colours:
More than 50 in stock
£12.66 ex VAT
£15.19 inc VAT
Charge and Sync your Apple Lightning-equipped devices over longer distances. The USBLT2MW 2m White Lightning to USB Cable for iPhone, iPod, and iPad provides a reliable solution for charging and syncing your newer generation Apple mobile devices with your PC or Mac computer, through an available USB port.
This longer Lightning USB cable offers 2-meters in cable length to overcome distance restrictions while still providing full charging power. Plus, the reversible 8-pin Lightning connector can be plugged into your iOS-enabled device with either side facing up, meaning there is no wrong way of inserting the cable into the device.
This durable cable is Apple MFi certified.
If your computer USB port does not deliver sufficient power and you see a "Not Charging" message on your iPad or other Apple device, you can use this 2m Lightning to USB Cable with the USB 2.0 Fast Charging Adapter (USB2CHADP) in order to fast charge your devices.
StarTech.com 2m White Apple 8-pin Lightning to USB Cable for iPhone iPad - Lightning cable - Lightning / USB - 2 m
Cable
Double shielded
American Wire Gauge (AWG)
24/28
Length
2 m
White
Connector
Lightning - male
Connector (Second End)
USB - male
Sync and charge
Apple iPad mini; iPad with Retina display (4th generation); iPhone 5; iPod nano (7G); iPod touch (5G)
Cable Type
Lightning cable
Interface Supported
Lightning / USB
Double shielded
24/28
Jacket Material
PVC
Shielding Material
Length
2 m
Plated Connector
Nickel
Sync and charge
White
Connector
Apple Lightning - male
4 pin USB Type A - male
RoHS
Apple iPad mini , Apple iPad with Retina display (4th generation) , Apple iPhone 5 , Apple iPod nano (7G) , Apple iPod touch (5G)
8T5L StarTech.com 1m (3ft) White Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad In Stock £11.71
8T5L StarTech.com 2m (6ft) Long White Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad In Stock £12.66
8T5L StarTech.com 0.3m (11in) Short White Apple 8-pin Lightning Connector to USB Cable iPhone iPod iPad In Stock £8.70
8T5L StarTech.com 15cm (6in) Short White Apple 8-pin Lightning Connector to USB Cable iPhone iPod iPad In Stock £11.70
8T5L StarTech.com 3m (10ft) Long White Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad In Stock £16.36
8T5L StarTech.com 1m (3ft) White Apple 8-pin Slim Lightning Connector to USB Cable for iPhone iPod iPad In Stock £9.91
8T5L StarTech.com 3 ft Angled Lightning Cable In Stock £13.73
8T5L StarTech.com 1m Metal Lightning Cable - White In Stock £13.24
Length: 2m
Price Range Ex VAT: 0 - 50
