StarTech.com 2m (6ft) Angled Black Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad
Quicklinx: 97RCWS00 Mfr#: USBLT2MBR
Colours:
Charge or Sync your iPhone, iPod, or iPad over longer distances, keeping the cable out of the way. The USBLT2MBR 2m Angled Lightning to USB Cable for iPhone, iPod, and iPad is colored to suit black mobile devices and provides a reliable solution for charging and syncing your newer generation Apple mobile devices with your PC or Mac computer, through an available USB port.
The angled Lightning connector positions the cable in such a way that it allows for easy access to your iOS-enabled mobile digital device in both portrait and landscape mode, even while charging.
The longer USB to iPhone cable design offers 2-meters in cable length to overcome distance restrictions while still providing full charging power.
Plus, the reversible 8-pin Lightning connector can be plugged into your iOS-enabled device with either side facing up, meaning there is no wrong way of inserting the cable into the device.
This durable cable is Apple MFi certified.
If your computer USB port does not deliver sufficient power and you see a "Not Charging" message on your iPad or other Apple device, you can use this 2m Lightning to USB Cable with the USB 2.0 Fast Charging Adapter (USB2CHADP) in order to fast charge your devices.
StarTech.com 2m 6ft Angled Black Apple 8-pin Lightning to USB Cable for iPhone iPod iPad - Angled Lightning Cable - Charge & Sync - 2 m (USBLT2MBR) - Lightning cable - Lightning / USB - 2 m
Cable
Double shielded
American Wire Gauge (AWG)
22/28
Length
2 m
Connector
Lightning - male
Connector (Second End)
USB - male
Angled connector
P/N: ARMTBLTIW, SECTBLTDT, SECTBLTPOS, STNDTBLT1A5T, STNDTBLT1FS, STNDTBLTMOB
Cable Type
Lightning cable angled connector
Interface Supported
Lightning / USB
Double shielded
22/28
Jacket Material
PVC
Shielding Material
Length
2 m
Plated Connector
Nickel
Sync and charge
Connector
Apple Lightning - male
4 pin USB Type A - male
RoHS
