Charge or Sync your iPhone, iPod, or iPad over longer distances, keeping the cable out of the way. The USBLT2MBR 2m Angled Lightning to USB Cable for iPhone, iPod, and iPad is colored to suit black mobile devices and provides a reliable solution for charging and syncing your newer generation Apple mobile devices with your PC or Mac computer, through an available USB port.
The angled Lightning connector positions the cable in such a way that it allows for easy access to your iOS-enabled mobile digital device in both portrait and landscape mode, even while charging.
The longer USB to iPhone cable design offers 2-meters in cable length to overcome distance restrictions while still providing full charging power.
Plus, the reversible 8-pin Lightning connector can be plugged into your iOS-enabled device with either side facing up, meaning there is no wrong way of inserting the cable into the device.
This durable cable is Apple MFi certified.
If your computer USB port does not deliver sufficient power and you see a "Not Charging" message on your iPad or other Apple device, you can use this 2m Lightning to USB Cable with the USB 2.0 Fast Charging Adapter (USB2CHADP) in order to fast charge your devices.
- StarTech.com 2m 6ft Angled Black Apple 8-pin Lightning to USB Cable for iPhone iPod iPad - Angled Lightning Cable - Charge & Sync - 2 m (USBLT2MBR) - Lightning cable - Lightning / USB - 2 m
- Cable
- Technology
- Double shielded
- American Wire Gauge (AWG)
- 22/28
- Length
- 2 m
- Black
- Connector
- Lightning - male
- Connector (Second End)
- USB - male
- Angled connector
- 2-year warranty
- Designed For
- P/N: ARMTBLTIW, SECTBLTDT, SECTBLTPOS, STNDTBLT1A5T, STNDTBLT1FS, STNDTBLTMOB
- Cable Type
- Lightning cable angled connector
- Interface Supported
- Lightning / USB
- Technology
- Double shielded
- 22/28
- Jacket Material
- PVC
- Shielding Material
- Aluminum mylar foil with braid
- Length
- 2 m
- Plated Connector
- Nickel
- Sync and charge
- Black
- Connector
- Apple Lightning - male
- 4 pin USB Type A - male
- RoHS
- Limited warranty - 2 years
- Designed For
StarTech.com Mountable 4 Port Rugged Industrial SuperSpeed USB 3.0 Hub | In Stock | £99.39 |
StarTech.com 6 Port USB 3.0 / USB 2.0 Combo Hub with 2A Charging Port – 2x USB 3.0 & 4x USB 2.0 | In Stock | £44.33 |
StarTech.com 1m (3ft) White Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad | In Stock | £15.34 |
StarTech.com 2m (6ft) Long White Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad | In Stock | £16.59 |
StarTech.com 1m (3ft) Black Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad | In Stock | £15.47 |
StarTech.com 4 Port USB 3.0 Hub plus 3 Dedicated USB Charging Ports (2 x 1A & 1 x 2A) | In Stock | £57.29 |
StarTech.com 7 Port SuperSpeed USB 3.0 Hub - Desktop USB Hub with Power Adapter – Black | In Stock | £51.70 |
StarTech.com Dual Port Car Charger with Apple 8-pin Lightning Connector and USB 2.0 Port | In Stock | £26.99 |
StarTech.com USB Wall Charger 17W / 3.4A x2 | In Stock | £15.45 |
StarTech.com 7 Port USB 3.0 Hub Desktop | In Stock | £71.57 |
StarTech.com 7 Port Industrial USB 3.0 Hub | In Stock | £111.54 |
StarTech.com 2x USB Wall Charger 17W / 3.4A | In Stock | £15.56 |
StarTech.com 10 Port Industrial USB 3.0 Hub | In Stock | £131.78 |
StarTech.com 10-Pt USB 3.0 Hub w/ Charging | In Stock | £66.89 |
StarTech.com 7-Pt USB 3.0 Hub + Charge Pts | In Stock | £60.86 |
StarTech.com 2x USB Car Charger 24W / 4.8A | In Stock | £12.35 |
StarTech.com 2x USB Car Charger 24W / 4.8A | In Stock | £11.54 |
StarTech.com 4 Port USB 3.0 Hub with USB C | In Stock | £44.99 |
StarTech.com 4PT USB 3.0 Hub - Charge Port | In Stock | £34.39 |
