StarTech.com 2ft Coiled Lightning/USB Cable
Quicklinx: BBD7WS00 Mfr#: USBCLT60CMW
Length: 60cm
Colours:
More than 50 in stock
£10.70 ex VAT
£12.84 inc VAT
Charge your iPad or iPhone inside its car mount. This coiled Lightning cable delivers the compact convenience you need to keep your mobile devices charged while you're driving, without cluttering up your car.
Simply plug the cable into your USB car charger and stretch it out to connect your mobile device when you need to charge it. You can extend the cable up to 2 ft (0.6m), to comfortably reach your car-mounted tablet or phone.
When you're not charging your mobile device, you can neatly store this compact cable in your car's storage console or glove box. Plus, it's portable enough to keep it in your laptop bag or carrying case, so you can have it handy when you arrive at your destination and use it as a conventional charge-and-sync cable.
The USBCLT60CMW coiled Lightning cable is Apple MFi certified.
StarTech.com Lightning to USB Cable - Coiled 0.3m (1ft), White - Lightning cable - Lightning / USB - USB to Lightning - 60 cm
Cable
Double shielded
American Wire Gauge (AWG)
28/30
Length
60 cm
White
Connector
USB - male
Connector (Second End)
Lightning - male
Coiled
Apple iPad Air; iPad Air 2; iPad mini; iPad mini 2; 3; iPad with Retina display (4th generation); iPhone 5, 5c, 5s, 6, 6 Plus; iPod nano (7G); iPod touch (5G)
Cable Type
Lightning cable
Interface Supported
Lightning / USB
Double shielded
28/30
Jacket Material
PVC
Shielding Material
Length
60 cm
Plated Connector
Nickel
Coiled
White
Connector
4 pin USB Type A - male
Apple Lightning - male
RoHS
Apple iPad Air , Apple iPad Air 2 , Apple iPad mini , Apple iPad mini 2 , Apple iPad mini 3 , Apple iPad with Retina display (4th generation) , Apple iPhone 5, 5c, 5s, 6, 6 Plus , Apple iPod nano (7G) , Apple iPod touch (5G)
Length: 60cm
Price Range Ex VAT: 0 - 50
