StarTech.com 25U Server Rack Cabinet
Quicklinx: D1VZWS00 Mfr#: RK2537BKM
Hurry, only 3 left in stock!
£881.15 ex VAT
£1,057.38 inc VAT
Securely store servers network and telecommunications equipment in this server network cabinet. This 25U server rack provides a sleek, secure cabinet for storing standard 19" rack-mount devices such as Dell, HP, and IBM servers, along with telecommunication and A/V equipment. The rack is compatible with EIA-310 compliant equipment and supports a total load capacity of 1500 kg (3307 lb.).
This rack offers a variety of features that make it easy to install your equipment. With adjustable mounting rails, you can easily change the rail depth from 3 to 37 in. (76.2 mm - 939.8 mm) to support full-depth equipment. The added depth also provides support for additional cable and power management behind your equipment.
The rack features grommet holes on the ceiling and floor panels, which make it easy to run cabling in and out of the cabinet for discreet cable management. The rack also features grounding lugs that enable you to ground your equipment for added protection, and tool-less accessory mounting rails so you can mount 0U vertical cable managers and PDUs.
For hassle-free cable management, the rack includes a 3-meter roll of hook-and-loop cable tie that makes it easy to keep your cables tidy. You can cut the self-gripping fabric to any size, and bind your equipment cables together or to the rack.
To keep your rack-mounted equipment secure, this rack features front and rear locking mesh doors that also increase airflow to provide passive cooling.
The rack also has a removable side panel with an independent quick-release lock that enables you to access your equipment easily, while still keeping it secure. Plus, a quick-release ceiling panel you can remove without interfering with cable runs that are running through your rack.
The cabinet features casters, providing ease of mobility around your office, studio or server room. Plus, the width and height of the rack fit through standard doorways, giving you the freedom to wheel your server rack into different rooms as needed.
  • Hassle-free equipment installation
    This rack offers a variety of features that make it easy to install your equipment. With adjustable mounting rails, you can easily change the rail depth from 7 to 35 in. (76.2 mm - 939.8 mm) to support full-depth equipment. The added depth also provides support for additional cable and power management behind your equipment. The rack features grommet holes on the ceiling and floor, which make it easy to run cabling in and out of the cabinet for discreet cable management. The rack also features grounding lugs that enable you to ground your equipment for added protection, and tool-less accessory mounting rails so you can mount 0U vertical cable managers and PDUs. For hassle-free cable management, the rack includes a 3-meter roll of hook-and-loop cable tie that makes it easy to keep your cables tidy. You can cut the self-gripping fabric to any size, and bind your equipment cables together or to the rack. To provide hassle-free deployment the rack ships fully assembled.
  • Keep your equipment secure, cool, and accessible
    To keep your rack-mounted equipment secure, this rack features front and rear locking mesh doors that also increase airflow to provide passive cooling. The rack also has a removable side panel with an independent quick-release lock that enables you to access your equipment easily, while still keeping it secure. Plus, a quick-release ceiling panel you can remove without interfering with cable runs that are running through your rack.
  • Maximum Maneuverability, with casters included
    The cabinet features casters, providing ease of mobility around your office, studio or server room. Plus, the width and height of the rack fit through standard doorways, giving you the freedom to wheel your server rack into different rooms as needed. The RK2537BKM is backed by a StarTech.com 5-year warranty and free lifetime technical support.
StarTech.com 25U Server Rack Cabinet, 4 Post Adjustable Depth 7" to 35" Locking Vented Mobile/Rolling Network/Data/IT Equipment Enclosure w/ Casters/Hook & Loop Dell PowerEdge, HP ProLiant - 25U Rack Cabinet (RK2537BKM) - rack - 25U
Rack
Rack Type
Cabinet
Package Content
Casters, 100 M6 cage nuts, 100 M6 screws
Rack Size
37"
Height (Rack Units)
25U
Product Material
Steel
60 cm x 107 cm x 123.73 cm
Key lock, removable door, mesh front door, mesh rear door, mesh side panels, adjustable rails, reversible front door
5-year warranty
Rack
Rack Type
Cabinet
Product Material
Steel
Package Content
Rack Size
37"
Height (Rack Units)
25U
60 cm
107 cm
123.73 cm
Inner Dimensions
57 cm x 100 cm x 111 cm
Weight Limit
1500 kg
Mounting Kit
Included
Limited warranty: - 5 years , Technical support: - lifetime
D1VZ StarTech.com 50 Pkg M5 Mounting Screws for Server Rack Cabinet In Stock £19.93
D1VZ StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg In Stock £99.99
D1VZ StarTech.com Universal VESA LCD Monitor Mounting Bracket for 19in Rack or Cabinet In Stock £48.25
D1VZ StarTech.com Adjustable Rackmount DIN Rail Kit with Top Hat/Mini/G Rails In Stock £83.08
D1VZ StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £13.74
D1VZ StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £35.39
D1VZ StarTech.com Black Standard Universal Server Rack Cabinet Shelf In Stock £34.53
D1VZ StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD In Stock £551.61
D1VZ StarTech.com 8 Port Rackmount USB VGA KVM Switch w/ Audio (Audio Cables Included) In Stock £337.14
D1VZ StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet In Stock £16.28
D1VZ StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £32.84
D1VZ StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £62.33
D1VZ StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £65.84
D1VZ StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg In Stock £28.76
D1VZ StarTech.com 16 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £575.96
D1VZ StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD In Stock £292.39
D1VZ StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £319.01
D1VZ StarTech.com 8 Port 1U Rackmount DVI USB KVM Switch In Stock £657.69
D1VZ StarTech.com 2U Adjustable Mounting Depth Vented Sliding Rack Mount Shelf – 50lbs / 22.7kg In Stock £92.59
D1VZ StarTech.com 4U Black Steel Storage Drawer for 19in Racks and Cabinets In Stock £120.51
D1VZ StarTech.com 1U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £68.86
D1VZ StarTech.com 2U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £84.94
D1VZ StarTech.com 3U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £88.30
D1VZ StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel In Stock £35.51
D1VZ StarTech.com 1U Adjustable Mounting Depth Rack Mount Shelf - Heavy Duty Shelf - 175lbs / 80kg In Stock £77.10
D1VZ StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - Heavy Duty - 250lbs / 113kg In Stock £92.81
D1VZ StarTech.com 2U 22in Depth Fixed Rack Mount Shelf - 50lbs / 22kg In Stock £55.50
D1VZ StarTech.com 2U 22in Vented Rack Mount Shelf – Fixed Server Rack Cabinet Shelf - 50lbs / 22kg In Stock £45.85
D1VZ StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg In Stock £39.89
D1VZ StarTech.com 2U Rack Mount Cantilever Shelf - Heavy Duty Fixed Server Rack Shelf - 125lbs / 56kg In Stock £53.98
D1VZ StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) In Stock £4.31
D1VZ StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) In Stock £7.01
D1VZ StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel In Stock £46.16
D1VZ StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £20.58
D1VZ StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £25.63
D1VZ StarTech.com 1U Server Rack Panel In Stock £13.04
D1VZ StarTech.com 100 Pkg M6 Screws & Cage Nuts In Stock £59.69
D1VZ StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £32.13
D1VZ StarTech.com 50 Pkg M6 Cage Nuts In Stock £22.74
D1VZ StarTech.com 100 Pkg M5 Cage Nuts In Stock £28.56
D1VZ StarTech.com 50 Pkg M5 Cage Nuts In Stock £17.25
D1VZ StarTech.com 100 Pkg M5 Screws & Cage Nuts In Stock £62.33
D1VZ StarTech.com 50 Pkg M5 Screws & Cage Nuts In Stock £32.84
D1VZ StarTech.com 50 Pkg M5 Mounting Screws In Stock £18.34
D1VZ StarTech.com 100 Pkg M5 Mounting Screws In Stock £34.53
D1VZ StarTech.com 50 Pkg M6 Mounting Screws In Stock £19.35
D1VZ StarTech.com 100 Pkg M6 Cage Nuts In Stock £26.55
D1VZ StarTech.com 100 Pkg M6 Cage Nuts In Stock £30.84
D1VZ Startech.com 100 Pkg M6 Mounting Screws In Stock £28.59
D1VZ StarTech.com 19in Cable Management Panel In Stock £24.78
D1VZ StarTech.com D-Ring Hook Cable Panel - 3ft. In Stock £41.93
D1VZ StarTech.com Finger Duct Cable Panel - 6ft. In Stock £88.31
D1VZ StarTech.com Finger Duct Cable Panel - 3ft. In Stock £53.53
D1VZ StarTech.com M6 Mounting Screws 50Pack In Stock £17.54
D1VZ StarTech.com 42U Server Rack Cabinet In Stock £1,388.47
Price Range Ex VAT: £750 - £1000
