Brand
StarTech.com 25U Adjustable Depth 4 Post Open Frame Server Rack Cabinet
Quicklinx: 6B9NWS00 Mfr#: 4POSTRACK25
Product Type: Rack, Rack
Hurry, only 1 left in stock!
£284.04 ex VAT
£340.84 inc VAT
StarTech.com's DuraRak 25U 4 Post Open Frame Rack/Cabinet provides a durable, open air housing for rackmount servers and networking equipment. The equipment rack/cabinet features heavy gauge mounting rails to ensure a stable installation platform and adjustable posts for flexible installation. The 25U rack is compliant with EIA-RS-310C standards, offering a universal design that's compatible with equipment from popular manufacturers. Plus, the equipment rack is flat-packed, reducing shipping costs and simplifying handling and assembly. The DuraRak 25U 4-Post Open Racks offer a durable housing for valuable equipment.
StarTech.com 25U Open Frame Server Rack - 994lb Capacity - 4 Post Adjustable Depth (18.3" to 39.3") Network/Communications Equipment Rack w/ Casters (4POSTRACK25) - rack - 25U
Rack
Flat black
Height (Rack Units)
25U
57.1 cm x 100 cm x 122.5 cm
39 kg
3-year warranty
P/N: CABCAGENUTS6, CABSCREWM5, CABSCREWM52, CABSCREWM6, CABSCREWM62, CABSCREWS, CABSCREWSM6, CABSCRWM520, CABSCRWM620, CABSCRWS1224
Rack
Height (Rack Units)
25U
57.1 cm
100 cm
122.5 cm
39 kg
Flat black
Weight Limit
450 kg
Limited warranty: - 3 years
6B9N StarTech.com 16 Port 1U Rackmount USB PS/2 KVM Switch with OSD In Stock £473.44
6B9N StarTech.com 50 Pkg M5 Mounting Screws for Server Rack Cabinet In Stock £18.83
6B9N StarTech.com 25U Adjustable Depth 4 Post Open Frame Server Rack Cabinet In Stock £284.04
6B9N StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg In Stock £83.25
6B9N StarTech.com 12U 19in Desktop Open Frame 2 Post Rack In Stock £45.28
6B9N StarTech.com 8U Open Frame Wall Mount Equipment Rack - 12in Deep In Stock £75.78
6B9N StarTech.com Caster Kit for Open Frame Rack - 4POSTRACK In Stock £41.74
6B9N StarTech.com Adjustable Rackmount DIN Rail Kit with Top Hat/Mini/G Rails In Stock £85.18
6B9N StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £13.28
6B9N StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £33.14
6B9N StarTech.com Black Standard Universal Server Rack Cabinet Shelf In Stock £33.34
6B9N StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet In Stock £15.71
6B9N StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £31.71
6B9N StarTech.com 1U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £66.49
6B9N StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel In Stock £38.16
6B9N StarTech.com 2U 22in Depth Fixed Rack Mount Shelf - 50lbs / 22kg In Stock £48.80
6B9N StarTech.com 2U 22in Vented Rack Mount Shelf – Fixed Server Rack Cabinet Shelf - 50lbs / 22kg In Stock £43.24
6B9N StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg In Stock £34.84
6B9N StarTech.com 2U Rack Mount Cantilever Shelf - Heavy Duty Fixed Server Rack Shelf - 125lbs / 56kg In Stock £47.69
6B9N StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 2.2x5.9in (5.7x15cm) In Stock £4.94
6B9N StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) In Stock £3.39
6B9N StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) In Stock £7.25
6B9N StarTech.com 2U Vented Sliding Rack Shelf w/ Cable Management Arm & Adjustable Depth 50lbs / 22.7kg In Stock £166.95
6B9N StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel In Stock £44.18
6B9N StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £24.99
6B9N StarTech.com 100 Pkg M6 Screws & Cage Nuts In Stock £63.56
6B9N StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £33.88
6B9N StarTech.com Portable Server Rack - 9U In Stock £253.32
6B9N StarTech.com 100 Pkg M5 Cage Nuts In Stock £27.44
6B9N StarTech.com 50 Pkg M6 Cage Nuts In Stock £21.95
6B9N StarTech.com 100 Pkg M5 Cage Nuts In Stock £33.34
6B9N StarTech.com 50 Pkg M5 Cage Nuts In Stock £16.65
6B9N StarTech.com 100 Pkg M5 Screws & Cage Nuts In Stock £60.18
6B9N StarTech.com 50 Pkg M5 Screws & Cage Nuts In Stock £31.71
6B9N StarTech.com 50 Pkg M5 Mounting Screws In Stock £17.89
6B9N StarTech.com 100 Pkg M5 Mounting Screws In Stock £33.69
6B9N StarTech.com 50 Pkg M6 Mounting Screws In Stock £18.70
6B9N StarTech.com 100 Pkg M6 Cage Nuts In Stock £29.13
6B9N StarTech.com 19in Cable Management Panel In Stock £23.93
6B9N StarTech.com 18U Server Rack Enclosure In Stock £436.98
6B9N StarTech.com 9U Wall-Mount Rack Cabinet In Stock £196.32
6B9N StarTech.com 12U Server Rack Enclosure In Stock £330.64
6B9N StarTech.com 15U Server Rack Enclosure In Stock £370.04
6B9N StarTech.com 12U Server Rack Enclosure In Stock £393.33
6B9N StarTech.com M6 Mounting Screws 50Pack In Stock £18.70
Product Type: Rack
Product Type: Rack
Stock Status: In stock
