StarTech.com 25U Adjustable Depth 4 Post Open Frame Server Rack Cabinet
Quicklinx: 6B9NWS00 Mfr#: 4POSTRACK25
Product Type: Rack, Rack
£294.18 ex VAT
£353.01 inc VAT
StarTech.com's DuraRak 25U 4 Post Open Frame Rack/Cabinet provides a durable, open air housing for rackmount servers and networking equipment. The equipment rack/cabinet features heavy gauge mounting rails to ensure a stable installation platform and adjustable posts for flexible installation. The 25U rack is compliant with EIA-RS-310C standards, offering a universal design that's compatible with equipment from popular manufacturers. Plus, the equipment rack is flat-packed, reducing shipping costs and simplifying handling and assembly. The DuraRak 25U 4-Post Open Racks offer a durable housing for valuable equipment.
StarTech.com 25U Open Frame Server Rack - 994lb Capacity - 4 Post Adjustable Depth (18.3" to 39.3") Network/Communications Equipment Rack w/ Casters (4POSTRACK25) - rack - 25U
Rack
Flat black
Height (Rack Units)
25U
57.1 cm x 100 cm x 122.5 cm
39 kg
3-year warranty
P/N: CABCAGENUTS6, CABSCREWM5, CABSCREWM52, CABSCREWM6, CABSCREWM62, CABSCREWS, CABSCREWSM6, CABSCRWM520, CABSCRWM620, CABSCRWS1224
Rack
Height (Rack Units)
25U
57.1 cm
100 cm
122.5 cm
39 kg
Flat black
Weight Limit
450 kg
Limited warranty: - 3 years
6B9N StarTech.com 16 Port 1U Rackmount USB PS/2 KVM Switch with OSD In Stock £490.32
6B9N StarTech.com 50 Pkg M5 Mounting Screws for Server Rack Cabinet In Stock £19.93
6B9N StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg In Stock £99.99
6B9N StarTech.com 12U 19in Desktop Open Frame 2 Post Rack In Stock £45.21
6B9N StarTech.com 8U Open Frame Wall Mount Equipment Rack - 12in Deep In Stock £78.51
6B9N StarTech.com Universal VESA LCD Monitor Mounting Bracket for 19in Rack or Cabinet In Stock £48.25
6B9N StarTech.com Caster Kit for Open Frame Rack - 4POSTRACK In Stock £43.23
6B9N StarTech.com Adjustable Rackmount DIN Rail Kit with Top Hat/Mini/G Rails In Stock £82.25
6B9N StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £13.74
6B9N StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £35.39
6B9N StarTech.com Black Standard Universal Server Rack Cabinet Shelf In Stock £34.53
6B9N StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD In Stock £551.61
6B9N StarTech.com 8 Port Rackmount USB VGA KVM Switch w/ Audio (Audio Cables Included) In Stock £337.14
6B9N StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet In Stock £16.28
6B9N StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £32.84
6B9N StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £62.33
6B9N StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £65.84
6B9N StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg In Stock £28.76
6B9N StarTech.com 16 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £575.80
6B9N StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD In Stock £292.39
6B9N StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £319.01
6B9N StarTech.com 8 Port 1U Rackmount DVI USB KVM Switch In Stock £657.69
6B9N StarTech.com 2U Adjustable Mounting Depth Vented Sliding Rack Mount Shelf – 50lbs / 22.7kg In Stock £92.59
6B9N StarTech.com 4U Black Steel Storage Drawer for 19in Racks and Cabinets In Stock £120.51
6B9N StarTech.com 1U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £68.86
6B9N StarTech.com 2U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £84.94
6B9N StarTech.com 3U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £88.30
6B9N StarTech.com 12U 36in Knock-Down Server Rack Cabinet with Casters In Stock £388.93
6B9N StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel In Stock £35.51
6B9N StarTech.com 1U Adjustable Mounting Depth Rack Mount Shelf - Heavy Duty Shelf - 175lbs / 80kg In Stock £77.10
6B9N StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - Heavy Duty - 250lbs / 113kg In Stock £92.81
6B9N StarTech.com 2U 22in Depth Fixed Rack Mount Shelf - 50lbs / 22kg In Stock £55.50
6B9N StarTech.com 2U 22in Vented Rack Mount Shelf – Fixed Server Rack Cabinet Shelf - 50lbs / 22kg In Stock £45.40
6B9N StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg In Stock £39.89
6B9N StarTech.com 2U Rack Mount Cantilever Shelf - Heavy Duty Fixed Server Rack Shelf - 125lbs / 56kg In Stock £53.98
6B9N StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) In Stock £4.26
6B9N StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) In Stock £7.01
6B9N StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel In Stock £46.16
6B9N StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £20.58
6B9N StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £25.63
6B9N StarTech.com 100 Pkg M6 Screws & Cage Nuts In Stock £59.69
6B9N StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £32.13
6B9N StarTech.com Portable Server Rack - 9U In Stock £262.35
6B9N StarTech.com 25U 36in Server Rack Cabinet In Stock £723.01
6B9N StarTech.com 50 Pkg M6 Cage Nuts In Stock £22.74
6B9N StarTech.com 100 Pkg M5 Cage Nuts In Stock £28.56
6B9N StarTech.com 50 Pkg M5 Cage Nuts In Stock £17.25
6B9N StarTech.com 100 Pkg M5 Screws & Cage Nuts In Stock £62.33
6B9N StarTech.com 50 Pkg M5 Screws & Cage Nuts In Stock £32.84
6B9N StarTech.com 50 Pkg M5 Mounting Screws In Stock £18.34
6B9N StarTech.com 100 Pkg M5 Mounting Screws In Stock £34.53
6B9N StarTech.com 50 Pkg M6 Mounting Screws In Stock £19.35
6B9N StarTech.com 100 Pkg M6 Cage Nuts In Stock £26.55
6B9N StarTech.com 100 Pkg M6 Cage Nuts In Stock £30.84
6B9N Startech.com 100 Pkg M6 Mounting Screws In Stock £28.59
6B9N StarTech.com 19in Cable Management Panel In Stock £24.78
6B9N StarTech.com 2-Post Desktop Rack - 8U In Stock £37.91
6B9N StarTech.com 18U Server Rack Enclosure In Stock £452.72
6B9N StarTech.com 6U Wall-Mount Rack Cabinet In Stock £149.52
6B9N StarTech.com 26U Server Rack Enclosure In Stock £495.72
6B9N StarTech.com 9U Wall-Mount Rack Cabinet In Stock £175.15
6B9N StarTech.com 9U Wall-Mount Rack Cabinet In Stock £194.68
6B9N StarTech.com 12U Server Rack Enclosure In Stock £402.13
6B9N StarTech.com 12U Server Rack Enclosure In Stock £277.35
6B9N StarTech.com 15U Server Rack Enclosure In Stock £344.58
6B9N StarTech.com 12U Server Rack Enclosure In Stock £377.14
6B9N StarTech.com 10-32 Server Rack Screws and Nuts - 50 Pack - Black - TAA Co In Stock £32.84
6B9N StarTech.com 4U Open Frame Desktop Rack - 2-Post - Weight Cap. 66 lbs In Stock £32.74
6B9N StarTech.com M6 Mounting Screws 50Pack In Stock £17.36
6B9N StarTech.com 42U Server Rack Cabinet In Stock £1,388.47
Product Type: Rack
Product Type: Rack
