This 25ft PS/2 Keyboard/Mouse Extension cable features a 6 DIN male connector and a 6 DIN female connector, allowing you to extend the connection distance between a PS/2 mouse or keyboard and the host computer by up to 25ft.
The extension cable offers a cost-effective and convenient way to connect PS/2 peripherals at longer distances than would typically be possible, allowing you to position peripherals as needed, without the hassle of connection length limitations.
- StarTech.com 25 ft PS/2 Keyboard Mouse Extension Cable - M/F - keyboard / mouse extension cable - 7.6 m
- Keyboard / mouse extension cable
- Length
- 7.6 m
- Connector
- 6 pin mini-DIN (PS/2 style) - male
- Connector (Second End)
- 6 pin mini-DIN (PS/2 style) - female
- Beige
- Limited lifetime warranty
- Designed For
- P/N: USB6N1DOCKGB, USB6N1DOCK
- Length
- 7.6 m
- Beige
- Connector
- FCC, RoHS
- Designed For
- StarTech.com 6-in-1 Black USB 2.0 Laptop Docking Station / Port Replicator
