StarTech.com 25 ft Flat High Speed HDMI Cable with Ethernet - Ultra HD 4k x 2k HDMI Cable
Quicklinx: 7NYPWS00 Mfr#: HDMIMM25FL
Length: 7.6m
20 in stock
£28.68 ex VAT
£34.41 inc VAT
Create Ultra HD connections between your HDMI-enabled devices with minimal clutter; supports Ethernet Data Channel. The HDMIMM25FL 25-foot Flat High Speed HDMI Cable with Ethernet supports Ethernet data interconnectivity with compatible HDMI devices and features a flat-shaft design that makes it suitable for in-wall installations or installation under carpet or along baseboards.
This high quality HDMI cable fully supports 1080p+ resolutions at up to 120Hz refresh rate, with life-like color. To accommodate the demands of future high definition devices, such as increased resolutions and higher frame rates, this Ultra HD cable supports resolutions up to 4k x 2k.
StarTech.com 25 ft Flat High Speed HDMI Cable with Ethernet - Ultra HD 4k x 2k - HDMI with Ethernet cable - 7.6 m
Cable
American Wire Gauge (AWG)
24
Length
7.6 m
Connector
HDMI - male
Connector (Second End)
HDMI - male
Cable Type
24
Jacket Material
PVC
Length
7.6 m
Plated Connector
Gold
Connector
19 pin HDMI Type A - male
RoHS
Limited warranty - lifetime
Length: 7.6m
Price Range Ex VAT: 0 - 50
