StarTech.com 25 ft DVI-D Single Link Cable - M/M
Quicklinx: 76S5WS00 Mfr#: DVIDSMM25
Type: Display
Length: 7.6m
Select:
£17.69 ex VAT
£21.22 inc VAT
This 25ft single-link DVI-D display cable offers a high quality connection that allows you to get the most out of your high-end digital video card and flat-panel digital LCD monitor. With DVI-D technology, no digital-to-analog conversion is necessary, so the signal is delivered faster and stronger than a standard monitor cable signal. The plug and play-compatible, all-digital connection is also ideal for connecting laptop computers to digital projectors for crystal-clear presentations. By interfacing two digital signals directly, you'll experience faster, higher-quality images. This single-link cable works with virtually any DVI digital flat panel LCD monitor and allows high-speed DVI video data transmissions of up to 4.95 Gbps.
StarTech.com 25 ft DVI-D Single Link Cable - M/M - DVI cable - 7.6 m
DVI cable - single link
Length
7.6 m
Connector
DVI-D - male
Connector (Second End)
DVI-D - male
Plug and Play
DVI cable
American Wire Gauge (AWG)
28
TMDS Links
Single link
Length
7.6 m
Connector
18+1 pin digital DVI (Single-Link) - male
Plug and Play
Type: Display
Length: 7.6m
Price Range Ex VAT: 0 - 50
