StarTech.com 25 ft DisplayPort Cable with Latches - M/M
Quicklinx: 68KPWS00 Mfr#: DISPLPORT25L
Type: DisplayPort
Length: 7.6m
£46.34 ex VAT
£55.60 inc VAT
This high quality 25ft DisplayPort cable provides a connection of up to 25ft between a DisplayPort source and a DisplayPort display, with no loss of signal quality - more than double the typical DisplayPort connection distance limitation (16ft).
Featuring 26 gauge (AWG) pure copper wire, the cable includes aluminum and Mylar shielding to help eliminate EMI and RFI interference and maintain signal integrity without any degradation of quality.
Supporting a maximum bandwidth of 10.8Gbps and display resolutions up to 2560x1600 (WQXGA), DisplayPort is capable of providing higher performance than either HDMI or dual link DVI. Each cable features small, USB-sized latching connectors with support for two-way display connectivity and optional audio support. Plus, DisplayPort cables feature a unique micro-packet architecture that supports new display features as the DisplayPort standard is further developed.
This 25ft DisplayPort cable is HDCP and DPCP compliant, ensuring that digitally protected content is displayed properly on the connected display.
StarTech.com 25 ft DisplayPort Cable with Latches - 2560 x 1600 - DPCP & HDCP - Male to Male DP Video Monitor Cable (DISPLPORT25L) - DisplayPort cable - 7.6 m
DisplayPort cable
Shielded
Latched
Length
7.6 m
Connector
DisplayPort - male
Connector (Second End)
DisplayPort - male
RoHS
P/N: CDP2DPHD, CDP2DPVGA, DPPNLFM3, DPPNLFM3PW, GCMDP2DPMF, HD2DP, HD2DPVGADVI, HDMI2DP, HDVGADP2HD, MDP2DPMF6IN, MST14DP123DP, MSTDP122DP, MSTDP123DP, MSTMDP122DP, MSTMDP123DP, SV231DPDDUA, SV231DPDDUA2, SV431DPUA, SV431DPUA2, TB32DP2, USB32DP4K
DisplayPort cable
Shielded
Shielding Material
American Wire Gauge (AWG)
26
Plated Connector
Nickel
Latched
Length
7.6 m
Connector
20 pin DisplayPort - male
RoHS
Type: DisplayPort
Length: 7.6m
Price Range Ex VAT: 0 - 50
