StarTech.com 25 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F
Quicklinx: 3ZK6WS00 Mfr#: MXT101HQ_25
Type: SVGA
Length: 7.6m
Hurry, only 3 left in stock!
£16.34 ex VAT
£19.60 inc VAT
This 25ft High Resolution VGA Extension Cable is designed to provide the highest video quality possible through VGA.
Ideally suited for high resolution VGA applications, this high quality male to female coaxial VGA extension cable helps to eliminates picture "ghosting" and fuzzy images inherent to non-coaxial cables, and provides superior EMI interference protection by using ferrite cores near the connector ends.
StarTech.com 25 ft High Res VGA Monitor Extension Cable M/F - VGA extension cable - 7.6 m
VGA extension cable
Coaxial
Molded
Length
7.6 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - female
P/N: VGANTSCPROEU, ST128UTPEAGB, USB2VGAPRO, USBVGADOCK2, ST122VGAU, USB2VGAE2, USBVGADOCKGB, VGA2VID, USB2VGAE, ST128UTPEA, USBVGADOCK, ST128W, ST124W, ST122W, USB2VGA2, USB2VGA, ST128UTPE, ST124UTPE, ST224MXGB, ST122PROAGB, ST124PROGB, ST128GB, VGANTSCPROGB, ST222MX, ST122PROA, ST1216PRO
VGA extension cable
Coaxial
Molded
Length
7.6 m
Connector
15 pin HD D-Sub (HD-15) - female
Startech Converge A/V 4 Port VGA Video Splitter - Wall Mountable, 8 Port VGA Video Splitter - Wall Mountable , StarTech.com 16 Port High Resolution VGA Video Splitter - 400 MHz, 2 Port High Resolution VGA Video Splitter with Audio - 400 MHz, 2 Port Matrix High Resolution VGA Video Splitter, 2 Port VGA Auto Switch, 2 Port Wall Mount VGA Video Splitter, 4 Port High Resolution VGA Video Splitter - 350 MHz, 4 Port VGA Matrix Video Switch - 250 MHz, 4 Port VGA Video Extender over Cat 5 (UTPE Series), 4-in-1 USB VGA Adapter and Docking Station, 8 Port VGA and Audio over Cat 5 Video Extender, 8 Port VGA Video Extender over Cat 5 (UTPE Series), High Resolution VGA to Composite or S-Video Converter PC to TV, Professional USB to VGA Multi Monitor Video Adapter, USB to VGA Multi Monitor External Video Adapter, USB VGA External Dual or Multi Monitor Video Adapter - Graphics adapter - Hi-Speed USB, USB VGA External Multi Monitor Video Adapter - High Resolution - Graphics adapter - Hi-Speed USB, USB VGA Mini External Dual or Multi Monitor Video Adapter, VGA PC to TV Video Converter with Remote Control, VGA to TV Video Converter with Remote Control , StarTech.com Professional VGA to NTSC/PAL TV Converter , StarTech.com VideoView 8 Port VGA Video Splitter, Pro 2 Port High Resolution 350 MHz Video Splitter, Pro 8 Port High Resolution 300 MHz Video Splitter
Type: SVGA
Length: 7.6m
Price Range Ex VAT: 0 - 50
