StarTech.com 25 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F
Quicklinx: 3ZK6WS00 Mfr#: MXT101HQ_25
Type: SVGA
Length: 7.6m
£16.20 ex VAT
£19.44 inc VAT
This 25ft High Resolution VGA Extension Cable is designed to provide the highest video quality possible through VGA.
Ideally suited for high resolution VGA applications, this high quality male to female coaxial VGA extension cable helps to eliminates picture "ghosting" and fuzzy images inherent to non-coaxial cables, and provides superior EMI interference protection by using ferrite cores near the connector ends.
StarTech.com 25 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F - 25ft VGA Extension Cable (MXT101HQ_25) - VGA extension cable - 7.6 m
VGA extension cable
Coaxial
Molded
Length
7.6 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - female
P/N: DP2VGAMM6, DP2VGAMM6B, DS128, DSRXL, HD2VGAMM6, MXT101MM, ST122PROEU, ST122PROGB, ST124PROEU, SV231USBLC, SV431USB, USBVGADOCK2
VGA extension cable
Coaxial
Molded
Length
7.6 m
Connector
15 pin HD D-Sub (HD-15) - female
Type: SVGA
Length: 7.6m
Price Range Ex VAT: 0 - 50
