StarTech.com 25 ft Cat5e Blue Snagless RJ45 UTP Cat 5e Patch Cable - 25ft Patch Cord
Quicklinx: 95FKWS00 Mfr#: RJ45PATCH25
Make Fast Ethernet network connections using this high quality Cat5e Cable, with Power-over-Ethernet capability. The 45PATCH25BL Cat5e Patch Cable (25 ft) meets or exceeds all Cat 5e specifications to ensure reliable Ethernet network connections, and features a durable blue PVC jacket that enables you to color code your network cable runs as needed.
To ensure long-lasting performance, this high quality Cat5e patch cable features a snagless design that protects the RJ45 connector clips from damage and makes the cable less prone to snagging during installation. The cable also features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance.
StarTech.com Cat5e cables are manufactured using high-quality copper conductors. While many cable manufacturers offer a "cheaper" cable, based on a copper-coated aluminum core, StarTech.com makes no compromises on quality to ensure you receive top value and performance for your network cable investment.
This Cat 5e cable is constructed with 24 gauge copper wire, to support a broad range of Ethernet applications such as Power over Ethernet (PoE). Because StarTech.com uses a high quality copper wire, StarTech.com cables easily sustain the power required for Power over Ethernet applications, whereas the inferior quality offered by copper-coated aluminum cables may be subject to insufficient power delivery, heat buildup, equipment damage and potentially, fire.
This RJ45 patch cable offers high quality connectors comprised of 50-micron gold, to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
  • Snagless RJ45 clips help protect your network connections
    For easier cable runs, the snagless connectors protect the cable's RJ45 clips during installation, making them less likely to snag or break. This ensures a sturdy connection by preventing the cable from becoming loose from the port. The cable features moulded boots that offer connector strain relief, by stopping the RJ45 connector termination points from bending at sharp angles, and reducing the risk of damage to the cable, which could decrease network performance.
  • 100% copper for outstanding value
    Get the highest value for your cable investment with our Cat 5e cables, each one manufactured using high-quality copper conductors.
  • 24-gauge wire for high-performance network connection
  • 50-micron gold connectors provide peak conductivity
    Rely on our RJ45 connectors to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion. The RJ45PATCH25 is backed by StarTech.com's lifetime warranty for guaranteed reliability.
StarTech.com 25 ft Cat5e Patch Cable with Snagless RJ45 Connectors - Blue - Cat 5e Ethernet Patch Cable - 25ft UTP Cat5e Patch Cord - patch cable - 7.6 m - blue
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Wires per Cable
8 wires
Snagless
Length
7.6 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Blue
P/N: BOX4HDECP2, DK30A2DH, KITBXAVHDPNA, KITBXDOCKPNA, MOD4AVHD, MOD4AVHDBT, MOD4DOCKACPD, MST30C2HDPPD, MST30C2HHPD, MST30C2HHPDU, ST121HD20L, ST121HD20V, ST121HDBT20L, ST121HDBT20S, ST121HDBTL, ST121HDBTSC, ST124HDBT, ST12MHDLAN4K, ST12MHDLAN4R, ST12MHDLNHK, ST12MHDLNHR, ST222HDBT, STDHVHDBT
Network Cable Type
American Wire Gauge (AWG)
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Snagless
Length
7.6 m
Blue
Connector
RJ-45 - male
RJ-45 - male
UL
P/N: BOX4HDECP, BOX4HDECP2, CABCONS1716I, COMPUTPEXTA, DK30A2DH, DS128, DSRXL, IPUSB2HD3, IPUSB2VGA2, KITBXAVHDPNA, KITBXDOCKPNA, MOD4AVHD, MOD4AVHDBT, MOD4DOCKACPD, MST30C2DPPD, MST30C2HDPPD, MST30C2HHPD, MST30C2HHPDU, PM1115P2, PM1115UW, PM1115UWEU, ST1000SPEX42, ST1000SPEX43, ST1212T, ST1214T, ST1218T, ST121EXT, ST121HD20L, ST121HD20V, ST121HDBT20L, ST121HDBT20S, ST121HDBT5, ST121HDBTD, ST121HDBTDK, ST121HDBTE, ST121HDBTL, ST121HDBTPW, ST121HDBTRP, ST121HDBTSC, ST121HDBTU, ST121R, ST121REU, ST121RGB, ST121SHD30, ST121SHD50, ST121USBHD, ST121UTP, ST121UTP232, ST121UTPDVI, ST121UTPEP, ST121UTPEU, ST121UTPGB, ST121UTPHD2, ST122UTPA, ST122UTPAL, ST124HDBT, ST124UTPEA, ST12MHDLAN, ST12MHDLAN4K, ST12MHDLAN4R, ST12MHDLANRX, ST12MHDLANU, ST12MHDLANUR, ST12MHDLNHK, ST12MHDLNHR, ST222HDBT, ST4000SPEXI, ST424HDBT, STDHVHDBT, STHDBTRX, STUTPEALR, SV565UTP, SV565UTPU, SV565UTPUL, SVIDUTPEXT, USB2HDCAPS, VS421HDPIP, VS424HDPIP, WIFI2HD2, WIFI2HDMC, WIFI2HDVGA
