Product
StarTech.com 25 ft Cat5e Blue Molded RJ45 UTP Cat 5e Patch Cable
Quicklinx: 4001WS00 Mfr#: M45PATCH25BL
Length: 7.6m
Colour: Blue
Stock Status: Clearance
Hurry, only 1 left in stock!
£5.09 ex VAT
£6.10 inc VAT
Express delivery Order within the next 15 hours for delivery tomorrow
Make Fast Ethernet network connections using this high quality Cat5e Cable, with Power-over-Ethernet capability. The M45PAT25BL Cat5e Patch Cable (25 ft) meets or exceeds all Cat 5e specifications to ensure reliable Ethernet network connections, and features a durable blue PVC jacket that enables you to color code your network cable runs as needed. To ensure long-lasting performance, this high quality Cat5e patch cable features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance. Constructed of only top quality materials, this Cat5e Patch Cord delivers reliable performance.
  • 100% copper - a better value
    StarTech.com Cat5e cables are manufactured using high-quality copper conductors. While many cable manufacturers offer a "cheaper" cable, based on a copper-coated aluminum core, StarTech.com makes no compromises on quality to ensure you receive top value and performance for your network cable investment.
  • 24 AWG wire
    This Cat 5e cable is constructed with 24 gauge copper wire, to support a broad range of Ethernet applications such as Power over Ethernet (PoE). Because StarTech.com uses a high quality copper wire, these cables easily sustain the power required for Power over Ethernet applications, whereas the inferior quality offered by copper-coated aluminum cables may be subject to insufficient power delivery, heat buildup, equipment damage and potentially, fire.
  • 50-micron gold connectors
    This RJ45 patch cable offers high quality connectors comprised of 50-micron gold, to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
StarTech.com 25 ft Blue Cat5e / Cat 5 Molded Patch Cable 25ft - patch cable - 7.6 m - blue
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Molded
Length
7.6 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Blue
P/N: ST121HDMR50, PEX100S, MCM110ST, PS2UTPEXT, USB6N1DOCKGB, USB6N1DOCK, BR4100DC
Network Cable Type
Wiring Scheme
T568B
American Wire Gauge (AWG)
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Molded
Length
7.6 m
Blue
Connector
RJ-45 - male
RJ-45 - male
StarTech.com 1 Port PCI Express 10/100 Ethernet Network Interface Adapter Card, 6-in-1 Black USB 2.0 Laptop Docking Station / Port Replicator, HDMI over Cat 5 Video Extender - Receiver, PS/2 Keyboard and Mouse Extender over Cat 5 , StarTech.com Converge A/V HDMI Over CAT5 / UTP Receiver
Length: 7.6m
Colour: Blue
Price Range Ex VAT: 0 - 50
