Make Power-over-Ethernet-capable Gigabit network connections. The C6PATCH25BL Cat 6 Patch Cable (25 ft) meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections, and features a durable blue PVC jacket that enables you to color code your network cable runs as needed. To ensure long-lasting performance, this high quality Cat 6 patch cable features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance. Constructed of only top quality materials, this Gigabit Patch Cable delivers reliable performance.
100% copper - a better value
StarTech.com Cat6 cables are manufactured using high-quality copper conductors. While many cable manufacturers offer a "cheaper" cable, based on a copper-coated aluminum core, StarTech.com makes no compromises on quality to ensure you receive top value and performance for your network cable investment. -
24 AWG wire
This Cat6 cable is constructed with 24 gauge copper wire, to support a broad range of Ethernet applications such as Power over Ethernet (PoE). Because StarTech.com uses a high quality copper wire, these cables easily sustain the power required for Power over Ethernet applications, whereas the inferior quality offered by copper-coated aluminum cables may be subject to insufficient power delivery, heat buildup, equipment damage and potentially, fire. -
50-micron gold connectors
This molded patch cable offers high quality connectors comprised of 50-micron gold, to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
- StarTech.com 25ft CAT6 Ethernet Cable - Blue Molded Gigabit CAT 6 Wire - 100W PoE RJ45 UTP 650MHz - Category 6 Network Patch Cord UL/TIA (C6PATCH25BL) - patch cable - 7.6 m - blue
- Patch cable - CAT 6
- Wiring Scheme
- T568B
- Wires per Cable
- 8 wires
- Molded
- Length
- 7.6 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Blue
- Limited lifetime warranty
- Designed For
- P/N: 110VDSLEX2EU, 110VDSLEX2GB, 110VDSLEXT2, AP150WN1X1OD, AP150WN1X1OE, AP300WN2X2W, IES61002POE, POEINJ1G, POEINJ1GW, R300WN22GA, ST1000SPEX42, ST1000SPEX43, ST4000SPEXI, USB31GEHD, USB31GEVG, USBA2DPGB
- Network Cable Type
- Wiring Scheme
- T568B
- American Wire Gauge (AWG)
- 24
- Wires per Cable
- 8 wires
- Pairs per Cable
- 4 pairs
- Molded
- Length
- 7.6 m
- Blue
- Connector
- RJ-45 - male
- RJ-45 - male
- CSA, ETL - up to 650 MHz
- Designed For
