StarTech.com 25 ft 3-in-1 Ultra Thin PS/2 KVM Cable
Quicklinx: 4KXDWS00 Mfr#: SVECON25
Connect VGA video and a PS/2 keyboard and mouse set using a single thin KVM cable
StarTech.com's professional line of 3-in-1 PS/2 KVM cables are specifically designed to work with your StarView or Server Remote Control KVM switch, integrating the necessary PS/2 peripheral connections as well as the VGA connection into a single cable - reducing tangles while maintaining excellent performance.
This 25ft 3-in-1 PS/2 KVM switch cable features an ultra-thin design and is constructed of only high quality materials. Designed for durability and long-term reliability, this cable is backed by StarTech.com's Lifetime Warranty.
The StarTech.com Advantage
  • Unique design minimizes the number of cables required
StarTech.com 3-in-1 Ultra Thin PS/2 KVM Cable - keyboard / video / mouse (KVM) cable - 7.62 m
Keyboard / video / mouse (KVM) cable
Length
7.62 m
Connectors
Connectors (Second End)
15 pin HD D-Sub (HD-15) - male , 2 x 6 pin mini-DIN (PS/2 style) - male
P/N: CAB1631HD, CAB831HD, CABCONS16, CABCONS1716I, CABCONS8, RACKCONS1908, RACKCONS1916, SV565UTP, SV831DUSBA, SV831HD, SV841HDIE, SV841HDIEGB
Length
7.62 m
Connectors
4KXD StarTech.com 4 Port Black PS/2 KVM Switch Kit with Cables In Stock £56.48
4KXD StarTech.com 16 Port 1U Rackmount USB PS/2 KVM Switch with OSD In Stock £490.32
4KXD StarTech.com 8 Port 1U Rackmount USB PS/2 KVM Switch with OSD In Stock £271.84
