StarTech.com 24in SATA Serial ATA Data and Power Combo Cable
Quicklinx: 7P20WS00 Mfr#: SATA24POW
Power your Internal SATA hard drive from an LP4 / Molex connector on your Power Supply. The SATA24POW SATA Data and Power Cable features a combination 22-pin SATA receptacle data and power connector as well as an Molex (LP4) power connector and SATA receptacle data connector, allowing you to create a conventional Serial ATA data connection to a computer while powering the drive through an LP4 connection to the computer power supply.
This high quality SATA power/LP4 adapter cable measures 24in, providing the flexibility required to position the SATA hard drive as needed within the computer case, while eliminating the expense of upgrading the computer power supply for the sake of SATA compatibility.
StarTech.com SATA Serial ATA Data and Power Combo Cable - SATA cable - 61 cm
SATA cable
Interface Speed
Serial ATA 150/300/600
Length
61 cm
Connectors
22 pin Serial ATA - receptacle
Connectors (Second End)
7 pin Serial ATA - receptacle , 4 PIN internal power - male
Red
P/N: HSB100SATBK, SATSASBAY3BK
Storage Cable Type
SATA cable
Interface Speed
Length
61 cm
Red
Connectors
RoHS
