StarTech.com 24in Latching SATA Cable
Quicklinx: 4LTLWS00 Mfr#: LSATA24
Length: 61cm
Type: ATA
Hurry, only 1 left in stock!
£4.50 ex VAT
£5.40 inc VAT
The LSATA24 SATA Cable features two latching 7-pin data receptacles and supports full SATA 3.0 bandwidth of up to 6Gbps when used with SATA 3.0 compliant drives.
The latching connectors lock when connected to a supporting (latchable) SATA port, ensuring a snug, and secured data connection every time to prevent accidental disconnects.
Featuring a low profile, yet durable construction, the flexible design improves airflow and reduces clutter in your computer case, helping to keep the case clean and cool.
StarTech.com 24in Latching SATA Cable - SATA cable - 61 cm
SATA cable
Interface Speed
Serial ATA 150/300/600
Latched
Length
61 cm
Connector
7 pin Serial ATA - receptacle
Connector (Second End)
Red
P/N: 35S24M2NGFF, BRACKET125PT, BRACKET125PTP, BRACKET225PT, BRACKET25X2, BRACKET425F, DRW110SATBK, HSB13SATSASB, HSB1SATSASBA, HSB1SATSASVA, HSB225S3R, HSB3SATSASBA, HSB43SATSASB, HSB4SATSASBA, PEXSAT32, SATSASBAY3BK, SATSASBP425, ST521PMINT, USB2SATAIDE, USB3SSATAIDE
Storage Cable Type
SATA cable
Interface Speed
Latched
Length
61 cm
Red
Connector
RoHS
Length: 61cm
Type: ATA
Price Range Ex VAT: 0 - 50
