StarTech.com 24in Dual Drive Ultra ATA IDE Hard Drive Cable
Quicklinx: 3ZLYWS00 Mfr#: IDE_
This 24in dual drive IDE cable is designed to fit as a new or replacement hard drive or CD-ROM cable in almost any size of computer case. The IDE cable allows you to connect two drives as Master and Slave drives, saving the space of having to use multiple cables to connect the drives.
StarTech.com Dual Drive Ultra ATA IDE Hard Drive Cable - IDE / EIDE cable - 0.6 m
IDE / EIDE cable
Length
0.6 m
Connector
40 PIN IDC - female
Connector (Second End)
2 x 40 PIN IDC - female
P/N: USB2SATAIDE, USB3SSATAIDE
Storage Cable Type
IDE / EIDE cable
Length
0.6 m
Connector
40 PIN IDC - female
