Organize up to 24 Cat6a patch cables using only 0.5U of rack space. This 24-port Cat6a patch panel is an efficient way to save space in your server racks.
The compact patch panel condenses 24 network ports into a 0.5U panel that's ideal for installations inside 19" server racks. It's constructed out of heavy-gauge steel and includes an easy-access cover that protects the terminated cables and helps to keep them organized at the back of the rack. The back of the panel also features a C-shaped cable-management system to provide strain relief.
The 24-port patch panel is color coded for both T568A and T568B universal wiring and offers straight ports with 110-type and Krone termination. The panel is shielded to protect against electromagnetic interference (EMI), when used with shielded cables. The panel will also support unshielded cables, but with no EMI protection.
The Ethernet patch panel is fully rated to support 10 Gigabit networks and is compatible with 26-23 AWG solid or stranded cables. It is also backward compatible with Cat6 and Cat5e cables.
The panel offers a quick and easy way to identify your cable runs. It has port numbers clearly marked on the front of each RJ45 port, and has a writeable/erasable marking surface for efficient system management.
- StarTech.com 24-Port Cat6a Patch Panel - 0.5U - Shielded - Dual IDC - patch panel - 0.5U - 19"
- Product Type
- Patch panel - CAT 6a - RJ-45 X 24
- Product Material
- Heavy gauge steel
- Port Qty
- 24 ports
- Height (Rack Units)
- 0.5U
- 2-year warranty
- Product Type
- Product Material
- Heavy gauge steel
- 0.5U
Cabling & Wiring
- Port Qty
- 24 ports
- Termination Type
- 110 type termination, LSA (Krone)
- 26-23 AWG
- Connector Provided
- 24 x RJ-45 female
- Rack Size
- 19"
- Cable management panel
- Limited warranty - 2 years
