StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel
Quicklinx: 9M78WS00 Mfr#: C6PANEL24
Ports: 24 ports
21 in stock
£36.44 ex VAT
£43.72 inc VAT
Organize up to 24 Cat6 patch cables. The C6PANEL24 24-port 110-type Rack Mount Cat 6 Patch Panel is color coded for both T568A and T568B wiring providing the perfect solution for any voice or LAN application.
For hassle-free connections, the patch panel offers straight Cat 6 ports with 110-type termination, making it easy to insert and remove your cables. The 24-port patch panel also offers a quick and easy way to identify your cable runs, with port numbers clearly marked on the back of each RJ45 port, and a writeable/erasable marking surface for each port on the front of the panel for efficient system management.
StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel - patch panel - 1U
Patch panel - CAT 6
Package Content
8 x screws
605 g
Port Qty
24 ports
Height (Rack Units)
1U
P/N: 2POSTRACK42, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25U, 4POSTRACK42, RK1219SIDEM, RK1219WALHM, RK1219WALLOH, RK1236BKF, RK219WALVO, RK2536BKF, RK419WALVO, RK419WALVS, RK419WALVSGB, RK619WALL, RK619WALLGB, RK619WALLOH, RK812WALLOA, RK819SIDEM, RK819WALLOH, RK960CP, RKQMCAB12, RKWOODCAB12
Patch panel - CAT 6
Package Content
8 x screws
Height (Rack Units)
1U
605 g
Enclosure Colour
Cabling & Wiring
Port Qty
24 ports
Termination Type
110 type termination
Connector Provided
24 x 110 female
-10 °C
60 °C
10 - 65%
P/N: 2636CABINET, 2POSTRACK42, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, CAB1019WALL, RK119WALLV, RK1219SIDEM, RK1219WALH, RK1219WALHM, RK1219WALL, RK1219WALLOH, RK1236BKF, RK12OD, RK219WALLV, RK219WALVO, RK2236BKF, RK2536BKF, RK319WALLV, RK419WALLV, RK419WALVO, RK419WALVS, RK419WALVSGB, RK4236BK, RK4242BK, RK619WALL, RK619WALLGB, RK619WALLOH, RK812WALLO, RK812WALLOA, RK819SIDEM, RK819WALLOH, RK960CP, RKQMCAB12, RKWOODCAB12, WALLMOUNT6, WALLMOUNTH1, WALLMOUNTH2, WALLMOUNTH4
Ports: 24 ports
Price Range Ex VAT: 0 - 50
